Login | Register
D2 5U Wet Clutch and Transmission
jsk
Send a private message to jsk
Hi. What are the recommended oils for a late model D25U
1) The wet Clutch on machine
2) Transmission on the tractor
3) Final drives
Also does anyone have the section of manual or some images from the manual on how much to fill the OIL clutch or how to adjust it ?
John
Mon, Jan 27, 2025 1:49 AM
jsk
Trying to get it working again..
Mon, Jan 27, 2025 2:23 AM
gemdozer
Reply to jsk:
The oil master cluch use the same oil than the motor and transmission and final drive use 80\90 gear oil
Mon, Jan 27, 2025 3:13 AM
jsk
Reply to gemdozer:
Thank You !
Greatly appreciated.
Mon, Jan 27, 2025 3:50 AM
josh
Here are the instructions for the D2 oil clutch, it does not take much oil, maybe a couple quarts, I can't find the exact amount right now, use the dipstick.
Mon, Jan 27, 2025 10:28 AM
jsk
Reply to josh:
Thanks for the information. Will keep everyone posted on the progress...
Mon, Jan 27, 2025 7:37 PM
  • Add an image
  • Showing 1 to 5 of 5 results
    KORUMBURRA WORKING HORSE & TRACTOR & 100 YEARS OF CAT RALLY
    | 5875 STH GIPPSLAND HWY, NYORA
    Booleroo 2025
    CAFES 2025 TULARE, CALIFORNIA
    | Tulare, California
    | 34 Henty Hwy, Warracknabeal
