Login | Register
1942 D47J D4400 pony losing oit - into pinion housing
CamaroMan
Send a private message to CamaroMan
hi all my 1942 d2 is up and running and happy to announce i got the main engine finally fired up and it sounds great-
I am noticing quite a bit of oil loss from the pony - and its making its way into the pinion housing (whuch was leakingn from the front cover so i sealed it up). I wasnt paying too much attention when i redid the bottom end- i did replace the main seal on the driver side, where else could the oil be coming from to make it into the pinion housing?
havent pulled bottom plug yet to see if its getting into clutch housing yet-
Sun, Jan 26, 2025 4:00 AM
rax200
Hi camaroman,
You will be loosing the oil through fhe rear main seal. In the parts book the seal is a 2b6005 which changes to a 5k2595 the info is found in the parts book under Crankshaft for the pony motor.
Regards
Sun, Jan 26, 2025 10:39 AM
CamaroMan
Reply to rax200:
Hi camaroman,
Regards
Hi replaced that with a new one but I think crank was a little worn. The seal felt like it was positively making contact but maybe I’ll pull it and throw on a speedy sleeve or epoxy and an updated seal.
I do have a lot of blow by probably not helping
Mon, Jan 27, 2025 12:00 AM
Reply to CamaroMan:
Hi CamaroMan, in addition to Daryl's comments, it's good to understand that there are three "chambers": the pony crankcase which as Daryl pointed out, has a crankshaft seal. That seal runs on a ring sandwiched between a shoulder on the crank and the gear. That must also be oil-tight. The second chamber is the one that that gear, the idler, and the pinion driven gear are in. It has its own oil fill/level/drain plugs and relies on that crank seal and the seal on the pinion shaft. Third is the pinion clutch chamber relying on the pinion shaft seal. So, there's really only two places that the oil can leak, and in seeing your description of the pony losing oil and the pinion clutch housing making oil, I'd conclude that both seals are leaking
Mon, Jan 27, 2025 2:04 AM
gemdozer
NEIL is right the motor oil has to leak to lubrificate the rear gears
Mon, Jan 27, 2025 3:19 AM
  • Add an image
  • Showing 1 to 4 of 4 results
    KORUMBURRA WORKING HORSE & TRACTOR & 100 YEARS OF CAT RALLY
    | 5875 STH GIPPSLAND HWY, NYORA
    Booleroo 2025
    CAFES 2025 TULARE, CALIFORNIA
    | Tulare, California
    | 34 Henty Hwy, Warracknabeal
