jig for drilling starter cutout on D318
NECat
Send a private message to NECat
I know this topic has been discussed extensively; adding electric start to D318 (D6 8U). I know a few members have built their own jig that fits on the two bolts on the side of the bellhousing to assist in getting the holes started when drilling. I was curious if anyone had a jig they used that they would sell? I recently acquired a D6 8U and a D6 9U that I would like to add the starter hole and bolts for electric start.
Mon, Dec 2, 2024 1:30 AM
Thank you received: 272
Auto-Lec? In Texas supplies a template with the starter kit; unsure if they would sell you only the template.
Here is a detailed drawing from long time member and crawler guru “Old Magnet”. This diagram has been floating about for some time, and nobody has had any issues that I am aware of.
Perhaps OM can chime in on any pointers.JM
Mon, Dec 2, 2024 2:13 AM
NECat
Thanks for the info juiceman. I see how bad of shape the pony is on one machine but I may just convert to electric to reduce frustration and more money down the road.
Thu, Dec 5, 2024 12:32 AM
Thank you received: 64
Reply to NECat:
You can drill it freehand - you don't need a jig. There's tolerance in the dimensions. I drilled my 5U bell housing freehand and it's fine. Just mark out the centers and check them twice and you'll be golden. Drilling the big hole with a hole saw goes surprisingly fast, maybe a minute or two
Thu, Dec 5, 2024 4:04 AM
NECat
Thanks Neil, I'll take my time marking out my measurements next week and start drilling.
Fri, Dec 6, 2024 10:11 PM
