D2 blade work
D2 blade work
Showing 1 to 10 of 16 results
Tugger
Send a private message to Tugger
Hi
i was moving some dirt with my D2 today.it seems nearly impossible to grade flat with this machine.one hump leads to abigger one .im not a catskinner by profesion,but i can usually make things flat with out resorting to the backblade.are these machines notoriously front heavy?this machine has a straight blade with hyd. tilt.seems like the blade is mounted quite far forward.do these machines need rear counterweight or a winch to improve balance or are they just not grading machines?
regards
Dave
Tue, Nov 11, 2008 11:52 AM
abram
Send a private message to abram
i'm no cat expert but i keep hearing things about severe balancing issues with the d2, not the greatest for dozing/leveling...but like i said i'm no expert.
3J5 D2
Tue, Nov 11, 2008 1:32 PM
dave morgan
Send a private message to dave morgan
Reply to abram:
One thing I have found that most of us can improve on, is to carry the blade-not try to cut a lot at once. Keep tension on cable control blade, don't push down with hyd blade and things will go a lot smoother.
Tue, Nov 11, 2008 3:13 PM
OzDozer
Reply to dave morgan:
The D2 is about the worst tractor you could ever put a blade on, and doze with. A short track frame, a blade that is way out front, and hydraulics that are less-than-stellar performance, means that even a skilled Catskinner has trouble with levelling with a D2.
The 5 roller trackframe and a counterweight in the form of a winch, improves them a great deal .. but they are still a tractor prone to severe and rapid pitching, which is the basic problem.
You can mollify the problems somewhat by always commencing dozing on a fairly level patch of ground, and by ensuring that there's a reasonable amount of dirt in the blade. A blade full of dirt is the best stabiliser against washboarding.
You need to develop rapid responses on the blade lever, to any tractor pitching - to the extent that you end up counter-acting any tractor pitching, rapidly, with the blade control, just as it happens.
Tue, Nov 11, 2008 4:06 PM
compressor
Send a private message to compressor
Reply to OzDozer:
Tugger,
Been there done that.
Having said that,there are two things that come to mind .
#1 do you have the larger front idler????? Alot of times people end up with d2 that's been retrofitted with a blade,but never had the front idle changed.
This happened to me.Your right, when you back up your little cat stands up on it's toes.And as far as grading,bottom line i don't care how good of skinner you are it's not going to happen.
#2 you did'nt mention the model of d2 that you have .Is it the later model, or earlier one .There is 6 or so inches difference between the two .This isn't much however the difference that it makes is great.
So, if you have a later model d2 with a large front idler.and can't grade, practice.
If you have a earlier model with a small front idler.you can knock it down,but you'll never make it smooth with a front push.
I have both those tractors.My newer one with the large idler is very easy to grade with .The older one with the small idler is impossible,but still fun to operate although can get so flustrating at times.
Anyway,this is a clear cut case where size really does matter.
JUST A THOUGHT COMPRESSOR
Tue, Nov 11, 2008 6:45 PM
timbo1946
Send a private message to timbo1946
Reply to compressor:
Tugger,
I have a D2 with the shorter track frame and small idlers. It has the Cat 2S blade. It is difficult to grade with. With that being said, a load of dirt on the blade helps greatly, also starting from a level position helps to control how you start your cut. When I start to get a wash-board, I usually stop, move over a little and try to continue. Back bladeing is a must for a reasonably smooth result. Lastly, it takes some practice, but you will get a feel for the tractor and almost have to anticapate what the tractor is going to do and counteract with the hydrolics before it happens, it is a nice challenge. I also find that after a long day, when I'm tired it get a whole lot harder, so I try to run the tractor for a little bit, do finish grading if possible before I'm tired. Hange with it, it does get better.
Tim
Tue, Nov 11, 2008 7:08 PM
Willie
Reply to timbo1946:
Tim
With a small dozer in some soils no matter what you do will not work here in Nor Cal we have areas with adobe that when dry you can cut it at all and when wet the minute the blade hits the ground it just keeps diggin deeper They have built adjustable skids behind the blades and such, but none seems to work. Ripping or discing it first will help. Later on the D4 blades came with tilting setup like the big dozers,you can turn both tilt turnbuckles tipping blade back so it rides on the moleboard. But in many cases a Ford 8N and box scraper or 2 wetbacks with shovles will do better then a D2 with Cat 2S blade. And any dozer opperator who has to make his work look good by back dragiing is no dozer opperator at all just a wannabe.
Tue, Nov 11, 2008 8:03 PM
ol Grump
Reply to Willie:
I've got both,a D4 with a 4A blade, another with a straight blade plus a D2 5J with a straight blade. It's quite a difference getting off a D4 and getting into the D2. Where with a D4 I can do a passable job, that D2 just about makes me tear out what little hair I have left. Even with a winch on the back, it's a real champ at making whoop de doos.
Any slack or wear in the linkages on these older critters can really make a decent job of blading a lot harder.
Tue, Nov 11, 2008 10:56 PM
Tugger
Reply to ol Grump:
thanks for all the responces.the machine sn. is 5j9260.would adding another roller and the larger diameter idler be as simple as extending the track frames,or are there other hidden considerations?Does anyone know where there might be a winch for a D2.I do have a gearmatic winch,but it dosnt seem like the proper winch .I also have another D2 sn. 4u1605,its a narrow guage drawbar only,no blade.Ive thought of building a c frame and angle blade for it.Any thoughts on blades on narrow D2 s?
Wed, Nov 12, 2008 1:39 AM
Packrat
Send a private message to Packrat
Reply to Tugger:
My D2 5u is also a challenge to grade with but I have a lot better results when the blade is angled.
Packrat
Wed, Nov 12, 2008 3:16 AM
compressor
Reply to Packrat:
Packrat
TUGGER,
As everyone out there has there own opinion on what will work and what will not.I have both tractors
#1 5u10850 short track frame and small idler.a cat 2a angle blade.
#2 5u17959 longer track frame and larger solid front idler with toolbar dozer.
The difference between the two is huge.
The older model ( such as your's) is almost impossible to grade with.Yes you can go 10' before it start's to get ugly,but them the flustration set's in and well you know what happens.
Then you climb on the newer one with the longer track frame and the larger front idler it's all together different.Is it the larger front idler or the longer track frame or both?
There is no way a d2 is going to compare with say a D6 just like a D6 prob would'nt compare to a patrol.As with everything,every piece of equipment large or small has it's place.
I promise you this ,if you change those idlers to the larger ones you will notice a hugggggge difference.Again,she won't be no D6,but you will be able to manage your frustrations alot better.
As far as adding a 5 roller I'm sure there are guy's out there have done just that.I thought of doing that very thing.I have an extra track frame and alot of rollers.Prob a big pain probably look like *&(%. So I never did.
One last thought. All the little d2's 3j 5j 4u 5u from the beginning to the lasts one made are great little tractors,but the later model in my humble opinion is alot more of a tractor which is very easily realize the moment you operate one.
Just a thought. COMPRESSOR
Wed, Nov 12, 2008 8:31 AM
Earlcoate Charity Open Day
