d47u
16 years 2 weeks ago #22599 by bob carlin
d47u was created by bob carlin
Hello everyone,
I am having hard time starting motor lately. Ran pony for 20 minutes today without any luck. Block was plenty warm, primar pump gauge was in the green, and injector rack was not stuck because I could vary fuel injector output by watching exhaust which would chang white to black. Still no start even with ether. When running it runs fine, just cant get there. Help. Whats next? Thanks for any help.
bob carlin d47u ser 15696
16 years 2 weeks ago #22601 by kenmcal
Replied by kenmcal on topic d47u
I don't know if this will help. My 5T done the same thing to me. I dis-engaged the clutch to the pony motor and it took right off. I had an old D6 that you had to dis-engage the clutch on the pony as well. If its rolling black smoke I would think that the diesel is running, and your pony just isn't dis-engaging. No expert, but thats my two cents. Does your pony riv when you throttle it up? Something to check.
Ken
16 years 2 weeks ago #22602 by bob carlin
Replied by bob carlin on topic d47u
Thanks for suggestion Ken
I dont think pony disengagement is a problem because it has not bee in past. As soon as main hit it would kick out, but I will try that tomorrow.
Thanks again Bob
16 years 2 weeks ago #22604 by ccjersey
Replied by ccjersey on topic d47u
Our 212 grader is the same way as Ken's stuff. If you get some black smoke and the pony sounds like it's having a very easy time turning it, try disengaging the clutch and see what happens.
16 years 2 weeks ago #22609 by bob carlin
Thanks ccjersey
while cranking motor with black smoke rolling, pony still sounds like it is under load. Having said that, I will still try your suggestion. I am at a loss.
Bob
16 years 2 weeks ago #22612 by OzDozer
Replied by OzDozer on topic d47u
Bob - Your pony may not be reaching full RPM, and thereby not reaching critical main engine cranking speed. It's difficult to tell by ear, whether a main has adequate cranking speed to light off.
Diesels rely on a cranking speed that is fast enough to generate ignition by compression, and if that cranking speed is down by even 50 RPM .. it may sound like the cranking speed is adequate, but it's not. You might be well advised to measure pony and main cranking speeds to see if they are down.
When the weather turns cold, it doesn't take much of a slight drop-off, of any one factor, to create the conditions where a main engine refuses to fire.
16 years 2 weeks ago #22614 by bob carlin
Ozdozer
I had even thought of that and was even going to get my digital tach but ran out of time. I know carb is not just right, will use tach and check it out.
Thanks Bob
16 years 2 weeks ago #22616 by D4Jim
Replied by D4Jim on topic d47u
Make sure the compression release is all the way to "start".
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
16 years 2 weeks ago #22618 by bob carlin
Jim
I have moved compression release in and out many times and no difference. Put new valve cover gasket on not too long ago and looked at linkage. All seemed to be ok. Stalled motor the other day and pull started it. Barely got maim clutch engaged and was suprised how quick it started.first time I had pull started. Will look compression release over again.
Thanks Bob
16 years 2 weeks ago #22761 by bob carlin
Thanks all,
Finally got chance to get back to problem with d4. Took your advice and kicked out pony clutch. I was surprised when diesel took off. One more thing I have learned in life. thanks for all the help.
Bob
Time to create page: 0.192 seconds
