Cat Motor Grader 112 3U5220 w/either 1H5768 or IH5768 on motor
1 month 2 weeks ago - 1 month 2 weeks ago #259589 by jamesneal6927@msn.com
Hi,  I'm trying to figure out any and all information about this particular motor grader.
Year, Pony Motor specs, anything that will make it a little easier finding parts.
The grader serial number: 3U5220
Engine: either 1 or i plus H5768 (1H5768)
UPDATE: transmission needed too. Cracked on left side and someone tried to weld it. :( I may be able to stitch it but that weld is big and long so... Other option is replacement.
Brake Master cylinder - for either rebuild kit or purchase rebuilt
Wheel slave cylinder - for either rebuild kit or purchase rebuilt
Would love to find a full install of parts for a ripper bar (shafts, bar, rippers, etc. everything)
Last edit: 1 month 2 weeks ago by jamesneal6927@msn.com.
1 month 2 weeks ago #259590 by gemdozer
The 3U motor is a D311 the same motor D2 dozer
The following user(s) said Thank You: Fat Dan, jamesneal6927@msn.com
1 month 2 weeks ago - 1 month 2 weeks ago #259592 by D4Jim
I believe the 3U series has the D315 engine, same as D4.  More rpm than the D4 and a lot more HP.
Model was made in 1955
Many various parts manuals for the 112 on eBay.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 1 month 2 weeks ago by D4Jim.
1 month 2 weeks ago #259593 by Fat Dan
🤔Humm what I gather from your post is you have a 112; 3U 5220 Motor Grader and the Diesel engine has been replaced with the engine S/N 1H 5768.
Is that correct ?
The 3U had the 4 cylinder D315*
The 1H 5729 to 1H 7692 are 1940 D8, 6 cylinder engines
* 🤔 Which brings up a good question... What year did the D315 start production ?
ACMOC Member
1 month 2 weeks ago #259595 by D4Jim
I believe the D315 came into existence in 1947. Jim Allen did quite extensive research on the D315 about 5 years ago but most of it was for a publication in a magazine other than ACMOC. I don't recall where it appeared but he frequented this forum at that time.
D47U 1950 #10164
1 month 2 weeks ago - 1 month 2 weeks ago #259597 by Fat Dan
Sorry, I was also going to add, if you put up some pictures we may be better able to help with answering your questions. I would also add a $45. membership to ACMOC gives you access to a plethora of online manuals that will answer all your questions on your model and give you invaluable insight to that model's quirks and idiosyncrasies. eBay is another good place to find manuals. I've found prices to be reasonable from $20 to $100 With that said, I have over $1000 in manuals for my No.311 Adams Motor Grader so $45 is cheap. And, and, AND did I mention that you get to mingle with fantastic like minded people?
ACMOC Member
Last edit: 1 month 2 weeks ago by Fat Dan. Reason: Cuz I forgot something
The following user(s) said Thank You: jamesneal6927@msn.com
1 month 2 weeks ago - 1 month 2 weeks ago #259598 by bruce oz
could the engine number 9S5768 , Industrial engine D315 -- 112 3U 5220 built 1955
Last edit: 1 month 2 weeks ago by bruce oz.
1 month 2 weeks ago #259600 by josh
1H5768 is the D315 block used on the 3U, 7U etc.
The following user(s) said Thank You: D4Jim, bruce oz, Fat Dan, jamesneal6927@msn.com
1 month 2 weeks ago - 1 month 2 weeks ago #259609 by jamesneal6927@msn.com
Hi Dan,
I didn't think this engine has been replaced and it's 4 cylinders.
I took your advice and joined.
Also, I've added pictures and a new need, discovered yesterday.
The transmission is definitely broke and needs mending or replaced. I'm in need of knowing the model of transmission and the types/models of equipment it was used in. Basically a cruise reference of sorts.
1 month 2 weeks ago #259617 by josh
That transmission was only used on the 112 grader.
Is your transmission failing/broken or just leaking at the weld ? if just leaking and the internals look ok, would think about patching it rather than replace.
Time to create page: 0.186 seconds
