Cat D7G Ripper
2 months 2 weeks ago #259117 by Snuffer61
Cat D7G Ripper was created by Snuffer61
I have purchased a Cat D7G s/n 92V77xx, it has a multi-shank ripper s/n 28K151. I am trying to find parts to reseal the lift cylinders. The 28K s/n prefix does not show up in Cat SiS parts program. My local Cat dealer can not find anything on it either. The tag is a Cat tag. It says "CHILE: M.R. MEXICO-MARCA RESISTRADA". So it appears it was made in Mexico. My question is where can I find a parts breakdown for these ripper lift cylinders?
Thanks in advance.
Blake
2 months 2 weeks ago #259123 by PhilC
Replied by PhilC on topic Cat D7G Ripper
There is a cylinder listed under 92V for 3J6429 cylinder GP that is for a ripper set. Is that anything like yours? SIS says it's for a later serial number machine.
2 months 2 weeks ago #259126 by Snuffer61
Replied by Snuffer61 on topic Cat D7G Ripper
Phil,
Thank you for the reply. I put that part number and s/n prefix in SiS but it says No search results available! I cant look at it.
I will look in the library here. I have found a cylinder group 2C6553 that looks close. However it shows a bolt in the head. My cylinder head screws on to the barrel.
2 months 2 weeks ago #259127 by Snuffer61
I can't find a 2J6429. Was your number supposed to be a 2J6439 maybe? That cylinder has a different style head.
2 months 2 weeks ago - 2 months 2 weeks ago #259128 by Old Magnet
Replied by Old Magnet on topic Cat D7G Ripper
I couldn't make s/n 28K work but the early 92V used a 12G-up #7 ripper (arrangement 9J567 replaced by 3G2022).
Uses cylinders #3J6439
More digging....28Kxxxx is a military s/n equivalent  to the 12G1-up.
Last edit: 2 months 2 weeks ago by Old Magnet.
The following user(s) said Thank You: bruce oz
2 months 2 weeks ago - 2 months 2 weeks ago #259129 by bruce oz
Replied by bruce oz on topic Cat D7G Ripper
serial number 28k no7 ripper 1967 military ,
Last edit: 2 months 2 weeks ago by bruce oz.
2 months 2 weeks ago #259130 by Snuffer61
Magnet and Bruce,
Thanks for that info. The 3J6439 cylinders are not like what is on this ripper. These cylinders have a round head that screws on to the barrel.
I'm going to measure the ID of the barrel later and see if I can determine the stroke.
What I'm needing are the pistons and seal kits. The two pistons that came out are aluminum and do not match. I don't know if the originals were aluminum. But I highly doubt it.
Blake
2 months 2 weeks ago #259132 by Snuffer61
Bruce,
Would you happen to have or know where I can get a parts break down of what cylinders were used on the 28K ripper.
Trying to see if they used different cylinders that the 12G s/n rippers.
Blake
2 months 2 weeks ago - 2 months 2 weeks ago #259133 by Old Magnet
Both cylinder options (correct) are 6" bore x 19.70" stroke (3J-6429 or 4T9290) and have four bolt heads.
I don't have the parts book but you might look into later rippers with s/n 12G7500-up or 82G1000-up to see if they used a different style cylinders.
2 months 2 weeks ago #259136 by bruce oz
The following user(s) said Thank You: Snuffer61
