Hey Fellas,
Basically very late last year i started my Dozer ready for a delightful day of earthmoving and it wouldn't go into gear. Forced out on the low pressure spring.
Got a new pump from Tilly's (ITR brand), installed it and went back to dozing away.
I've probably put 20 hours on the machine this year and last week (after i picked up my ACMOC magazine from the post office that reminds me my membership is due) went to start it and it's springing out of gear again.
When you first start it it's fine, after a few minutes it looses pressure. When you rev it up you can hear the pump kick in and it makes the correct pressures at the test ports on top of the trans (350psi and 250psi or 300 and 250 from memory but we checked it against the book and it was good), drop the revs with the decellerator and the pressure drops away. When you remove the pressure guage line the oil is really air-rated.
When the machine is cold The Converter oil pressure guage shows High in the red, once it warms up it sits in the upper green area. When it's having this issue while cold the converter pressure guage reads in the middle of the green, when you rev it and get trans pressure it goes up in the high area, once you lose the pressure it drops back to sitting in the middle of the green or low green) Not sure if this is related but just something i noticed.
Removed the pump and it's making all the right squelching noises, no movement, drive gear is on ect.
Pickup Hose between the trans and the pump is only 5 years old, plenty flexible and Cat hose clamps that are nice and tight. Replaced the O-ring on the trans side as it had a minor damage to it but no difference. O-ring on the pump side of the pipe is good.
Filter after the pump is clean (one very minor piece of what looked like silicone), there isn't a pre-screen installed on that side, it was a bit of an inbetween S/N where they started going to the magnetic screens up by the engine, and they are on the clutch/steering side.
Put an extra 10l of oil in and no difference, no major leaks to loose that much oil quickly anyway. Oil level comes up the stick in the low pressure state and well above the add line when it's got pressure.
Anything else i can check? O-rings on the tubes that run inside the trans were replaced when we rebuilt it 5 years ago. I don't want to go in there again. Is there something i can spray or put on the pickup line to see if it's sucking air through a crack or somthing?
www.acmoc.org/bb/discussion-d72/32122-ca...g-in-gear-at-low-rpm
This bloke had a very simular problem but i was expecting more then 20 hours of out of a pump that cost me over $1000...
66A01872
