D4 7U hydraulic level
catman58
Send a private message to catman58
Does anyone know how to check and where to check the hydraulic oil for the blade on a 7U D4? The resivoir is in front of the radiator and I took the cap off that thinking there may be a dip stick on the cap but there wasn't one. Not sure where to go from there.
Tue, Aug 6, 2024 4:28 AM
seiscat
The oil should be visible in the filler neck of your NO.44 hydraulic control on your D4 7U. If you are a "paying" member and can access the ACMOC library please read the Operation and Maintenance Instructions(OMI) for the NO. 44 hydraulic control.
Craig
Tue, Aug 6, 2024 4:51 AM
seiscat
Reply to seiscat:
Craig
If you want your own copies I found these on eBay. You really need both, they will save you time & money & heartaches.
Craig
D4 7U:
https://www.ebay.com/itm/404441554546
NO. 44 hydraulic control:
https://www.ebay.com/itm/375373987442
Tue, Aug 6, 2024 5:20 AM
Thank you received: 34
Reply to seiscat:
Craig
D4 7U:
oil should be just visible at the bottom of the filler neck. any more and it will overflow as the oil expands with heat.
Wed, Aug 7, 2024 7:19 AM
Thank you received: 100
Reply to trainzkid88:
I have my own question about correct oil level/amounts for a #44 unit with the surge tank. What is the proper amount? Someone said only 1/4 full, here I run them about 1/2 full. I have seen some folks get a bath from too much. Also, is the system supposed to be able to breathe? Factory cap has no obvious means of ventilation. Thoughts? TIA JM
Wed, Aug 7, 2024 9:38 PM
Thank you received: 24
My understanding is that the surge tank is maintained around 50%, and the system is pressurized so the cap needs to be on tight after priming. Had to go through the process of priming my buddy's HT4 which has the surge tank arrangement. This was all from the service reference or operator's manual - can't remember which
Wed, Aug 7, 2024 11:47 PM
