D7 3T Injection
D7 3T Injection
Showing 1 to 10 of 10 results
CatMan2
Send a private message to CatMan2
I have a D7 3T25880. Sat for 3 years but with the normal routine got the pony running, got the main rolling and ten minutes later it was running. Got on to see if the blade was still working and had to adjust the brake or I wasn't going anywhere. Did that, got back on, gave it a little more throttle thinking I take it for a walk, and when I did it just sound like It would when you normally shut down. I think the fuel valve at the tank may have been closed but not sure. I moved the valve around after I undid the fuel line to make sure I had good flow so don't know. Also I have fuel pressure. I've seen it have more but it is there. The gauge is almost to the green.
Next day fired the pony and rolled it over for 40 minutes. Have fuel out of both bleed holes on front of injection tower but nothing coming thru when injector lines a cracked. Tried again today for 15 minutes with the same results so stopped to regroup.
I made a tool for the bleed valves at the injection, but I tried a couple and the amount of torque I was putting on them told me to stop. Don't need to brake one off.
Am I missing something simple that I've never seen. This is my 5th D7 and never had an injection issue before. It seems like the fuel isn't making it to the distributer portion and I'm wondering how to check in the simplest fashion before I start ripping into it.
Fri, Aug 2, 2024 5:49 AM
Thank you received: 13
Take the side cover off the injection pump and check to see if lifters are moving.
Fri, Aug 2, 2024 6:29 AM
CatMan2
Took the cover off and lifters are moving.
Fri, Aug 2, 2024 8:29 AM
Reply to CatMan2:
Whens the last time you changed fuel filters and cleaned out any sludge in the filter housing? You may be making pressure but not flow.
Sat, Aug 3, 2024 12:46 AM
clayton
Online
Check your fuel rack to make sure it’s moving, I’ve seen some stick and act the way you are describing your faults. Also pressurize your fuel tank a little psi to get things moving faster doesn’t hurt.
Sat, Aug 3, 2024 4:24 AM
CatMan2
Reply to clayton:
Thanks guys! I got my bleeders loosened up, cranked it over and got juice, closed them all and had juice at injector lines. Snugged them up, waited a minute or two, flipped the compression release off and away she went. Took her for a drive and shoved some dirt around and she seems pretty happy. They say they have injection pump filters at the cat dealer, and I should probably change them. 21 bucks a filter and 5 bucks a gasket. Not unreasonable. When I had the side plate with 6 bolts off it made me wonder if that is bathed in oil or not and if so from where. The Big plug with the slot in it came off easy and it seemed like there was fuel in there. Should it be fuel or do I need to look further, Also the plug with the 11/16 square extension I didn't open because I needed a breaker bar and didn't want to screw up the square drive so thought I'd soak it down and try later. What behind that plug? Anyway I'm way ahead of where I was.
Sat, Aug 3, 2024 4:53 AM
Reply to CatMan2:
There should be engine oil behind the big slotted plug on the injection pump. If it is fuel you have a problem. The square plug below the two bolt cover is the drain plug for the filter housing. You need to invest in a service manual and Operation manual plus actually do some maintenance.
Sat, Aug 3, 2024 7:09 AM
seiscat
OM is correct, The Operation and Maintenance Instructions(OMI) is full of useful information that will save you time and money. It may prevent you from making a mistake. There is a OMI in the ACMOC library or I have one for sale cheap, if you want it send me a private message.
Craig
Sat, Aug 3, 2024 8:23 PM
CatMan2
Reply to seiscat:
Craig
Is the oil in the in the reservoir below the injection pump 30 weight. I've got to look closer at what's in there. It just seemed a little thin so I assumed it was diesel. Years ago I had a military field parts book. Great exploded drawings of every part nut and bolt. It explained things as well. Beautiful book and well worn, used. Like and idiot I let a guy have it that bought my first d7 from me. At the time I figured I'd get another one when the day came. Didn't know what I had until I tried finding another. Anything I've seen isn't quite the same but yes I do need and would like to have a good book or two so let me know what you've got Craig.
Sun, Aug 4, 2024 3:43 AM
Reply to CatMan2:
Seems your referring to the War Department Manual  TM5-3092. Very good reference. Couple of them on ebay now.
Yes, 30 weight engine oil for the injection pump sump.
Sun, Aug 4, 2024 3:55 AM
seiscat
Reply to CatMan2:
I have all the books for your D7 3T. Back in the day Cat had separate books for each attachment, the blade, the hydraulic system or cable control unit. I've scanned all of them and submitted them to the ACMOC library. If you are a paying member you can access them for free. I have them for sale now. Below are the ones for the basic tractor. I have the other ones also. Send me a PM and let me know what you need.
Craig
 [attachment=77283]13.jpg[/attachment]
 [attachment=77284]16.jpg[/attachment]
 [attachment=77285]25.jpg[/attachment]
Mon, Aug 5, 2024 11:47 PM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
