Welding oil pan?
6 months 2 weeks ago #258236 by brokestroke
Welding oil pan? was created by brokestroke
Got a 1955 HT4 that came without a belly pan.  Well today it wedged a stump into the oil pan putting a big hole in it.  It dumped oil but I caught it right away and shut it down.  Upon shutdown there was no knocking or indications that the motor is toast.  Crawled under it and its got about a fist sized hole in the pan with a couple cracks.  The dozer runs and works well and it is very unfortunate.
Has anyone ever built a patch plate and welded it in place?  How does the pan weld?  Not sure what kind of cast they used.  Building a patch plate is no problem for me.  Interested if anyone here has done it.
6 months 2 weeks ago #258237 by juiceman
Replied by juiceman on topic Welding oil pan?
Never welded one up here, but consider yourself somewhat lucky it did not break where the springs rest. That particular spot gets worn paper thin sometimes and difficult to repair. I have always wondered if someone could fix pans in that spot with a powder torch or spray arc? Ideally one would have to be sure of decontaminating where you plan on patching. I am guessing you didn't plan on removing it from the machine? A royal pain either way. Good luck. JM
6 months 2 weeks ago #258238 by brokestroke
Replied by brokestroke on topic Welding oil pan?
No springs on this tractor being that an HT4 it has a solid beam.
6 months 2 weeks ago #258247 by brokestroke
Decided to make a patch plate and bolt it to the remaining oil pan to seal it up.
6 months 2 weeks ago - 6 months 2 weeks ago #258248 by blwatson
Replied by blwatson on topic Welding oil pan?
Check out a post " 212 (?) sump repair without disassembly vidio"  by a user named Haus, posted 8 months and 1 week ago. I would attach it but do not know how. I found it interesting. They used a wire feed welder in small, short welds and pinged with a needle gun.
D47U
Last edit: 6 months 2 weeks ago by blwatson.
6 months 2 weeks ago #258249 by brokestroke
Started forming a plate to cover the hole.  Going to bolt it in place, there is enough meat left on the old pan to do so.  Going to take a bit to get it matched up just right.  Everything is too oily to weld as well as it's location makes it tough.  Onced fixed I will build a heavy duty belly pan so it never happens again.
6 months 2 weeks ago #258258 by neil
Replied by neil on topic Welding oil pan?
My buddy has an HT4 that does have a belly pan. We're planning to take it off to clean and I was going to suggest to leave it off and "be careful" but I'm rethinking that suggestion now : )
6 months 1 week ago #258333 by brokestroke
Got it all patched up. $100 worth of loctite steel putty and 2 tubes of ultra black rtv.  Decided to use thru bolts to hold the plate in place instead of tapping it.  Went together pretty well, very dirty work crawling under that thing.  Hope the old girl is still healthy.  Going to fill it with oil, turn it over for a while with the compression released and hope for the best.
 [attahment=77218]20240725_214120.jpg[/attachment]
6 months 1 week ago #258364 by D4Jim
Replied by D4Jim on topic Welding oil pan?
Hope the fix holds!!!
I'd be a nervous wreck waiting for something to leak all the oil out again while operating. :) :)
Best of luck!! This will truly put Loctite to the test!
My D4 is an ag tractor and no belly pan which I wish it had. I use mine for a lot of demolition around the farm with the dozer and always worry about the pan.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 months 19 hours ago #260637 by brokestroke
Dozer is running great, no leaks or anything to be concerned about.  Ended up building a huge skid plate for it that is 200-250lb and over 1" at its thickest.  Worked it pretty hard for the rest of the summer with no problems.
The following user(s) said Thank You: D4Jim, Busso20
Time to create page: 0.186 seconds
