Did you look in the parts manual to see what kind of fitting the carb inlet takes. Chances are that it isn't an NPT thread but rather a ferrule and collar of some sort.My 17A had an NPT threaded fitting which leaked and my carb guy says he sees split cast iron inlets due to using NPT threads.
The TU4C carbs have 1/8" npt inlet threads.
