I often wonder when looking at really worn handles how many hours the previous owners must have used a tractor to wear them out. Have seen them worn until the metal is starting to show through the plastic. Also find it interesting on some tractors that spent a lot of time pulling grain drills or combines that some farmers modified or put different grips on the right and the left steering clutch levers so that they would not accidentally pull the wrong one while looking over their shoulder. Mike
The early Caterpillars from the 20’s and 30’s had octagon on the left and round on the right so you wouldn’t grab the wrong one 🤣
I think we have a handful of tractors with handles left. But most of them are either bare threads or some amalgamation that someone put on long before us. Our 28 is a great example. The clutch, and gearshift are small pipes that someone wedged on, and the turning levers were cut and had some metal pieces welded on. So in short, I don’t think we’ve ever changed handles. Not yet anyways. [attachment=76982]IMG_5709.jpeg[/attachment]![]()
I have thought enough about replacing some handles I have bought new ones. Then broke the threads off trying to remove the old one. Other than fixing the real have to now one...........................................the rest of the new handles are in storage until.............................who knows.
Yes, I do not know HOW some would wear their handles out. Seen some where it looked like they rested their hands on top, and only wore one side off, as if they pulled with palm of their gloves. Others worn evenly, as if they had a death grip on them for thousands of hours. Others torn clean off the lever, and broken grease gun handles wedged in place as an extension.
I think I will get some of the fancy chromed and glittered ones for one of my toys...
Ray54: The use of heat helps quite a bit, got to make them glow and work back and forth. Stripping or breaking threads is not fun. JM
SoCalCatMan, Does your Twenty Eight have the single compartment fuel tank?
I was some what disappointed with the last handles I got from Cat. The bottom of the plastic is now even with the flats of the hex for the wrench. It use to be that the Bakelite was even with the points of the hex which would have made it easy to make the hex handle used on the early tractors.
Naylorbros, yes it’s a single tank. No compartment for alternative fuels other than the main tank.
