Newly acquired Ten
Newly acquired Ten
Thank you received: 6
2 months 2 weeks ago #257665
by 2 Fingers
Hello all, and thank you in advance for any help and guidance. I recently acquired a 1930 Caterpillar model Ten (#3594) and am slowly getting into it. It was in the same family since purchased new in 1929 and I promised them that I would make it run again and share it's history with the others. Right now I have fuel, air, and spark, but very low cylinder compression. I had the same issues on an Oliver HG 42, but some motor honey on top of the pistons generally creates enough compression to make it run long enough to get the rings broke loose. What I'd like to know about is the seat dimensions. I have the wooden frames for the back and sides, as well as the box springs for the seat, but I don't know how thick each piece should be. The seat remnants I found suggest that they were black leather, secured with tacks. I'd appreciate any help with dimensions or pictures of how to rebuild the seat properly. I'd also appreciate any guidance on other problems to look for. I know the crawler sat in a hay shed for a lot of years and inside cold storage for probably the last ten years. It hasn't run in probably 30 years, but very surprisingly, it is very complete and in pretty good shape for its age.
Thank you received: 13
Thank you received: 722
2 months 1 week ago #257691
by juiceman
That's a cute one. One day I'll have one too, that is, if AntiqueCatman21 doesn't buy all of them up first! JM
2 months 1 week ago #257696
by 2 Fingers
Thanks. Even though it's 19 years older than my Oliver/Cletrac HG 42, they make a pretty nice pair.
Thank you received: 97
2 months 1 week ago #257701
by side-seat
Nice survivor !
Bend the seat back vertical and put a seat on it and leave it alone. You could contact Haun for a new seat.
2 months 1 week ago #257703
by 2 Fingers
I got the seat back bent back where it's supposed to be and managed to hammer out the crease without further damage. Is it fair to assume that Haun is an ACMOC member and I can find them here?
Thank you received: 326
2 months 1 week ago #257706
by seiscat
Since you are a "member" not a "user" you can use the "members" selection to see the ACMOC magazine. The Haun seats ad is on the inside of the back cover.
Craig
Thank you received: 147
2 months 1 week ago #257712
by Skinner
Nice original looking TEN. That could be original paint. Please don’t paint it. as far as getting it running pull start it the first time to get the rings loosened up then they start easy with the crank. Skinner
2 months 1 week ago #257715
by 2 Fingers
Thanks Craig. I'm new to the world of Caterpillar and ACMOC so I'm still figuring things out, it seems like a great community to be part of.
Newly acquired Ten
