922B hydraulics
922B hydraulics
5 months 2 days ago #257608
by Cat4usNZ
Hi, I have a 922B that had water in the hydraulic tank when I bought it. I drained the oil and changed the filter & flushed it with more oil (low hour hydraulic oil from a new digger but clean). It was fine for a while but now the lift control valve won't move. The tilt is fine. I have taken the lid off the hydraulic tank and the lift spool is not frozen, it will move very slightly. Could it be a detent problem?
Any recommendations would be appreciated.
Thank you received: 121
5 months 2 days ago #257610
by PhilC
Does the auto kickout or positioner work? Maybe they are stuck on and stopping the spool from moving.
Thank you received: 28
5 months 2 days ago #257612
by ChrisE
I wonder if there is a tiny piece of debris jamming the valve. A piece of debris that is small enough to not be visible can jam the valve. Blow some air around the spool to see if it will free up. Good luck.
922B hydraulics
Time to create page: 0.137 seconds
