First time D6B owner
Thank you received: 815
5 months 2 weeks ago #257269
I agree, those near crimped injection lines need to be replaced but a check of the parts book shows they did not utilize clamps.
If you go changing lines, they all need to be of equal length if fabricated. Best to get Cat parts if available.
Thank you received: 58
5 months 2 weeks ago #257279
by Mschwartz
I will look at my D6 B to see how the injector lines are routed, yours make me wonder if turbo was added and the lines were bent to clear? I will try to grab a pic for you. Question about the tracks showing the idler out near the front of the track frame, don’t the longer D5 6.92 links start out a lot farther forward than the original 6.75 pitch links? I ask because I have a tractor with what I think are like new d5 chains on it and the idler sets way forward also. Thanks, Mike
Thank you received: 928
5 months 2 weeks ago #257280
by Deas Plant.
Hi, Mschwartz.
You may well be right about the turbo being added on but I still can't see any good reason why the injector pipes would need to be bent the way they are, especially considering the pressures that they work under.
5 months 2 weeks ago #257281
by mopardude318
So once these are converted to 6.91 pitch using a welded ring on the sprocket, and bolted on segments, I assume the track chain is also replaced as well to match? What about the upper and lower support rollers. And the big front roller wheel ( what’s the proper terminology)
5 months 2 weeks ago #257282
by mopardude318
I would like to replace those injector lines. I’ll go to Cat tomorrow and see if they are available and check pricing.
Hi, Mschwartz.
5 months 2 weeks ago #257283
by Deas Plant.
Hi, mopardude.
Replacing one without the other would be kinda a recipe for disaster.
Remember, if they can't find those injector pipes or the D6B listings, ask them to look in "Classic Caterpillar". You will need the engine serial # and any arrangement #s that might be on that tag.
Thank you received: 346
5 months 2 weeks ago - 5 months 2 weeks ago #257286
by seiscat
Thanks for the pictures. Your tracks show very little wear other than the track pads. They are genuine Caterpillar.
The injector lines never had clamps/braces. This is the D6B parts book. I also looked up the lines in my parts book for the D6C 74A(turbocharged) (bottom pic) and the numbers are the same.
This page is the back cover for the OMI for the D6B.
Your S/N looks like 44A4305. You confirm that by looking for it here.
Craig
Last edit: 5 months 2 weeks ago by
seiscat. Reason: add info
5 months 2 weeks ago #257287
Mike
When doing the 6.91 change over there is on less link than the 6.75 arrangement so the overall track length is the same. eg: 40 to 39 links.
5 months 2 weeks ago #257288
Seiscat
Looking at some more of the track pictures there does seem to be an odd link in there with the Cat part number but not the same cat logo/designation.
5 months 2 weeks ago #257289
by mopardude318
Thank you for those part numbers. They are all available from CAT. $768.81 for all of them. Could I go aftermarket?
Craig
