D2 Pony governor lube????
Thank you received: 108
5 months 4 weeks ago #257062
by GrantJ
My D2 5U has a stuck pony governor. Really stuck, even with a tap hammer and lots of PB Blaster the lever wont move. I took a governor off of a parts D2, so I am OK, but I cant figure out how to lubricate or check the oil in the governor. My 5U manual does not even mention oil in the governor and my 3J manual seems to say you have to dis-assemble the unit to add oil. Is there something that I am missing? I dont want the replacement to go bad from lack of oil. Thanks Guys. Grant.
Thank you received: 276
5 months 4 weeks ago - 5 months 4 weeks ago #257063
by rax200
Hi Grantj,
The instructions sat to take out one of the 4 screws and pump 2 or 3 squirts from an oil can in and replace the ecrew.
Hope this helps
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 5 months 4 weeks ago by
rax200. Reason: Spelling
Thank you received: 214
5 months 4 weeks ago #257064
by bruce oz
i am sure you only need to remove one screw and use oil can to lube .- 2 Tablespoons of oil
5 months 4 weeks ago #257066
by GrantJ
I saw a mention of that in a 3J manual, but no photo. I took the screws out of the other end and could not get oil to go in. Now I understand. . The old story of "A picture is worth a thousand words".
It wont help the one I took off. The shaft that the control lever is on is stuck and wont budge.
I am lucky that I have a parts machine laying around. Thanks a lot, Grant.
5 months 4 weeks ago #257067
by GrantJ
I am curious bruce oz, which manual did you find the drawing in? Thanks again, Grant.
5 months 3 weeks ago #257082
by GrantJ
I looked at 5 different manuals today. Three actual Cat books , one Jensales and another repo that I dont recall the name. The three Cat books each had a little bit different wording about the governor and surprisingly the Jensales had the best description. I had always thought Jensales were just repos of cat books, but there must be more D2 books out there than I know about because it was a little different wording than the other three actual Cat books. Just another mystery in Catworld. Grant.
Thank you received: 658
5 months 3 weeks ago - 5 months 3 weeks ago #257090
The part I don't understand about that oiling advice from Cat is how any oil gets to the other end of the governor, where there are more parts that could do with lubrication. Perhaps they rely on it running down there when the machine is on an angle. When I assembled the 5U's governor, I put extra oil in that end cover and more than a tablespoon in the pulley end.
Last edit: 5 months 3 weeks ago by
neil. Reason: Correct spelling
5 months 3 weeks ago #257092
by GrantJ
I agree, it seems like the design team forgot to make maintenance easy. I hope to get mine back on today and see how it responds. Thanks all Grant.
5 months 3 weeks ago #257101
by bruce oz
how any oil gets to the other end of the governor ? - Centrifugal Force by the governor arms would push oil to the other end
Time to create page: 0.186 seconds
