D4 7u pinion bearings
5 months 2 weeks ago #257346 by Jimmy977
Replied by Jimmy977 on topic D4 7u pinion bearings
Ok thanks for info
5 months 2 weeks ago #257366 by trainzkid88
Replied by trainzkid88 on topic D4 7u pinion bearings
If you can come up with a set of books from I.B.I. International Bearing Interchange they will have all the bearings cross referenced .
These are not published anymore but if you can find a set they will solve your dilemma .
Good luck
Bob
yes the uncle had a CBC bearings bearing bible when he worked at mount isa mines the idiot lost it and has regretted it since. it had the crossmatch for most bearing manufacturers.
5 months 2 weeks ago #257367 by trainzkid88
if you goole the cat part number and can find the national stock number you can find a cross reference that way. this can also work in reverse for floyd he can search the timken etc pn and then via the nsn find the cat numbers. yes lot of work but might be worth it.
5 months 1 week ago #257436 by Floyd Green
Replied by Floyd Green on topic D4 7u pinion bearings
Thanks folks, I finally see some light at the end of this long tunnel! I really would like to know what I have. Recently a friend from our military equip. club spotted some #s on a pile of nine bearings. He recognized them as (TIMKEN) outer front wheel bearings for a WWII White half track.
5 months 1 week ago #257446 by bluox
Replied by bluox on topic D4 7u pinion bearings
Post the number of one Timken bearing and I will look it up in the bearing interchange .
I will post the info it has.
Bob
5 months 1 week ago #257479 by Floyd Green
Thank you very much again Bluox. FAFNIR 313W
5 months 1 week ago #257484 by brian18a
Replied by brian18a on topic D4 7u pinion bearings
cat number 1b4123
5 months 1 week ago #257496 by bluox
As per I.B.I. guide
FAFNIR 313W
Index book see group 14275
groups book 14275
MOI = open single row ball bearing
2.5591 ID
5.5118 OD
1.2992 W
Cat 1B4123
1B4123-6
3B4520
50018
50038
5A158
+130 other interchange bearing numbers
This is what I meant by a set of these books would really help you if you have a lot of bearings to cross over.
good luck
Bob
Time to create page: 0.157 seconds
