Transmission Cover Gasket
Showing 1 to 10 of 25 results
bernie
Revisting this topic for reasons I will post in a few days. The last photo is of the CAT Gasket Part Number 3B889. Two are required. I have been skeptical of these as they do not appear to match the underneath side of the cover. This is the gasket that keeps the gear box oil from splashing outside of the compartment.
The other two are my attempt to find a solution. This is a 7/16 inch square "graphite Impregnated Aramid Packing". It is a product cut from a spool to length.
The 3B889 is a 3/8" square. I used the 7/16" to allow for some compression of the seal.
Anyway my question is, does the photo of the CAT gasket appear to be what others have used. Trying to keep from being cheap, I really do not want to bust the package on this $44 gasket.
I have to do some repairs due to the packing material not working out. I am happy to use the CAT gasket if it is the right product, if not I will find an alternative. My cover is on, but will need to be removed as the 7/16 inch packing is not the right product for the job...believe me.
Thanks-
bernie
Wed, Oct 29, 2008 7:11 AM
greyhead
Send a private message to greyhead
Hey bernie;
I really hope that the repairs you speak of do not include high heat and brass filler rod
I say this because the casting looks like it could crack or bust due to overtightening in areas because it is unsupported at the bolt circle around the outside.
Also will a thick gasket give you linkage alinement problems?
Why not use the blue CAT brand rtv sealant on that case as it is subject only slung oil and not below oil level
only my opinion ,and we all know about opinions!
CAT 977K-11K, JD450-B ,JD690-B, IH TD-9 ,CASE 450-B JD750-E JD850-B
CAT D7-3T, KOMATSU P-68-8 LGP, CLARK 55A LOADER
CLARK MICHAGAN 85-C LOADER, CAT V60 FORKLIFT
And some old AC tractors
Wed, Oct 29, 2008 7:54 PM
bernie
Reply to greyhead:
Hey bernie;
Greyhead,
Well, you hit it. Shock and awe Saturday. It took my son and I over an hour to seat the cover as my hoist reach is not long enough. Crib and lower, crib and lower a little at a time. I spent an hour carefully tightening around the case alternating on opposite bolts a little at a time with only a short handled ratchet so not to apply too much torque.
Finally we resolved to remove it as the linkage did not match as you suggest and I did not want to pull it down any more. . While working with the main clutch linkage prior to loosening the cover bolts the "pop" occurred. Not a big crack, but a crack. I was sick.
I have a buddy coming over tonight or tomorrow to weld it before I remove it. I will replace the gasket and move on. I build a temp rafter overhead to assist in its re-installation. I really thought the seal material was a better product than the cork gasket. I regret if anything not sticking to the 3/8"...the packing is a pretty dense material but I hammered it to soften it some prior to install.
I was avoiding the RTV-I would opt for the gasket, event he high $$$ from CAT if I thought it were the right tool. Still not sure. Making one is no biggie, but the thickness is still bothersome due to the void in the rim of the case where the gasket is supposed to seat. The thickest material I found is 1/4 inch.
Anyway, the weld will be in place by weeks end. And moving on from there. Regardless it was/is nice to see the cover in place. Good news is I still have not unwrapped the CAT gaskets...
Thanks for looking this over and thinking it through.
bernie
Wed, Oct 29, 2008 8:48 PM
ol Grump
Reply to bernie:
Greyhead,
bernie
Bernie,
Sorry to hear about the problems. I got to thinking that if there's a hydraulic supplier/shop close, you might call 'em about O-ring stock. It's made in a bunch of different sizes and compositions for those that have the kit to make their own o-rings. Basically ya cut it to length and use some type of Superglue to glue the ends together. Instant o-ring!
When I reworked my steering clutches I reused the old seal. .along with some gookempuckey (RTV Silicone) and haven't seen any sign of a leak yet. As I recall, the old seal had a sort of "D" shape to it but it could have taken that shape from the years it had been in there. A fairly soft o-ring material of the right diameter (3/8" diameter?) would probably do the job.
Thu, Oct 30, 2008 9:55 PM
bernie
Reply to ol Grump:
Bernie,
It is such a silly and simple issue to even bring up. By now anyone seeing my posts knows I put it all out there. I have checked with tranny shop and no oring that big. Your read my mind. I do not want to use silicone unless I have to. I do not want to use the CAT gasket as it just does not look right and too much money.
What would work the best I think is solid wood stove rope gasket imregnated with graphite. Not as dense as the packing I used. The packing was the solution except it is too big...why there is not an extruded cork stock or square/rectangular cork stock available, I am not sure.
I may use a 1/8" homeade I have already started and use silicone filler for the groove.
Welding up the crack this evening. Next step over the weekend.
bernie
Fri, Oct 31, 2008 3:24 AM
greyhead
Reply to bernie:
bernie
Hey, bernie;
Check your local -Motion industries- they will have O-rings of 1/4 to 5/16 dia. you will need to come up with the major dia around the case.
They will ask what mat. buna or viton
buna is the softest and cheaper viton is for higher heat and higher pressure FYI
If not I have rolls of 1/4x1/2 neoprem rubber sticky on one side and oil rated
PM if this will work its a drive but not a long one.
Fri, Oct 31, 2008 7:26 PM
bernie
Reply to greyhead:
Hey, bernie;
Greyhead-
I was just in Greensburgh yesterday...I ordered some Buna 3/8" solid last night from mcmaser carr. not here until tuesday-$.65/ft, not bad.
calling around today at some local shops to see what i can find. do not want to wait until next week.
cover fixed as of last night. removing this eveing-cleaning up the mess i have made and moving forward..
i may get with you-thanks for the suggestions.
bernie
Fri, Oct 31, 2008 8:05 PM
jeffscarstrucks
Send a private message to jeffscarstrucks
Reply to greyhead:
Hey, bernie;
Your local boiler supply company (large heating systems) has a wide array of bulk gasket material in many different materials and sizes. You want to get to th oldest guy behind the counter. JEFF
Fri, Oct 31, 2008 8:10 PM
bernie
Reply to jeffscarstrucks:
On a whim I went to my bearing "go to guy" this afternoon. When I called him he had the 3/8" cord, but only five feet...I knew I needed closer to six...I went over anyway to snoop around-I asked him to get me the bag with the rubber cord...label read "five feet"...I said, hey let's measure it...we did...70 inches...may be close, but I think it will work.
If you need something, try Neil at Tri-State Bearing. Located in Bloomington Vincennes Evansville Indiana at least. Maybe elsewhere.
"...Seek and ye shall find..."
Anyway, thanks for all the suggestions. Planning on getting back to it this evening. Kids are too old to Trick or Treat, so I think I can stay home.
bernie
Sat, Nov 1, 2008 1:12 AM
Mike Meyer
Thank you received: 5
Reply to bernie:
bernie
I'm getting ready to bolt the tranny top back on my D4 7J and was looking through old posts researching the correct gaskets to use when I came across your posts Bernie, thanks for sharing your experience at the time.
How did the 3/8th "O" ring cord work out for sealing the actual gearbox, and what material did you decide on for sealing the rear of the transmission around the steering clutches and behind the crown wheel housing where you didn't use the 3/8th rubber cord? I have access to the rubberised cork in different thickness's, not sure how easy it will be to access that 3/8th "O" ring material, because like you, I'm not married to Paris Hilton so a buck is a buck to me, and $44 for each gaskets sounds like a lot of coin to this little Black Duck!😆
regards
Mike
Tue, Apr 3, 2012 9:20 AM
bernie
Reply to Mike Meyer:
regards
Mike
[quote="Mike Meyer"]I'm getting ready to bolt the tranny top back on my D4 7J and was looking through old posts researching the correct gaskets to use when I came across your posts Bernie, thanks for sharing your experience at the time.
regards
Mike[/quote]
Hi Mike-
Still turning away I see! I have had no issues with the rubber cord. I have only put 20 hours on it since I installed the cover, nothing real rugged, but I was operating on a pretty steep stockpile for several of those.
Around the steering clutch compartment, I think that was just metal on metal. I looked over my parts book and none is called for best I can tell. BUT...something....something tells me I made one anyway. Punched holes at the bolts holes and nothing fancy. We will need some help here. Voices in my head seem to tell me no gasket necessary. I may have added one to make up just a smidge of gap caused by the 3/8" cord to AVOID busting my cover again. I also looked at my picture trail and the before pics of the tranny cover removal do not indicate a gasket. Just some rust I think from the metal on metal contact.
http://www.picturetrail.com/sfx/album/view/17962583
The cover over the bull gear is a CAT felt gasket. That pic is on the Picturetrail too. Fit right in, but if I remember right you need to be careful putting the cover on as it will walk off its seat.
I will look at some other photos I may have and see if I can dig something else up.
[attachment=12733]007.jpg[/attachment]
OK...edit if image attachment worked. This is a photo of my cover install. No gasket around the steering clutch compartment....metal on metal.
Tue, Apr 3, 2012 10:03 AM
