D6 9U steering issue
Showing 1 to 10 of 16 results
Ricky
Send a private message to Ricky
found a D6 9U for sale,  started it,pony runs good, it moves forward and reverse, right steering clutch stuck open not engaging right clutch handle soft, and moving but no back pressure the plunger is stuck open?? Any suggestions does this have an internal return spring ?? if you pull the left clutch arm the dozer stops moving, the clutch on the right is stuck in the open position not engaging any comments would be of great value, would help me decide whether to buy or not 9U188204 what year is this? pony only, closed area has no hole or taps for electric starter
Thank You, Ricky
Sun, Mar 24, 2024 4:28 AM
Thank you received: 15
The clutches do have springs that hold the disks in engagement - about eight springs arranged around a hub. One guess is that the disks are hung up on a ridge worn into one or both of the hubs. It's a medium size job to refurbish the steering clutches. Parts are available. The main criterion for dozer value is the undercarriage condition. You can determine it by taking various measurements. The easiest way is with a gauge designed for the D6 which is just a flat piece of plate with various cutout that when place against the item to be evaluated, shows the 0 and 100% worn sizes - 100% worn is economically worn out. The other way is to measure to a precision of about 1/8" in order to get a good estimate of the size. There's a diagram on this forum somewhere that shows the measurements to take (someone will chime in with where to find it) and the typical parts measured are: idler profile, roller profile, sprocket tooth wear, and rail height from the grouser plate, and the grouser height itself. A diagram also exists on how to drill the holes required to fit an electric starter for the main engine.
Sun, Mar 24, 2024 4:57 AM
Ricky
it feels more like the issue is in the clutch oil control under the fuel tank?? the clutch stick is like free nothing to pull against??
Sun, Mar 24, 2024 7:54 AM
Reply to Ricky:
Oh ok, I forgot about that. Yes, perhaps the lever inside it is hanging up. You can look in the serviceman's reference for instructions on how to dismantle it. If is is hung up, careful that it doesn't pinch your fingers when it lets go
Sun, Mar 24, 2024 9:24 PM
Thank you received: 12
There are a number of things that could be wrong, to fix most of them disassemble is required. Not a real hard job to get it apart. Since I don't type fast or well, how much experience do you have with old iron? Crawlers in particular. How much history can you get. The springs should be such that the handle is returned so the clutch is engaged and pulling the track. Makes me wonder if the hydraulic steering booster is out of oil and dry parts stuck as you pulled the lever, or when the last guy pulled the lever. Or someone has the linkage way off. Not thinking of many reason the handle is loose and no power. Several things if the lever is good and no power. Now is not the time to worry about that.
By serial number you should have a wet master clutch, which has the hole drilled and taped for a starter. The number says it is a 53 to 56 year without getting a book out.
Mon, Mar 25, 2024 6:00 AM
Ricky
Reply to Ray54:
anyone know the year and horsepower for this 9U188204 ???
Mon, Mar 25, 2024 7:06 AM
D4Jim
Thank you received: 5
Reply to Ricky:
[quote="Ricky post=255585 userid=10510"]anyone know the year and horsepower for this 9U188204 ???
[size=150]Are you sure about that Serial Number??
 [/size]
 [/quote]
Cats Forever
Mon, Mar 25, 2024 8:22 AM
Ricky
Reply to D4Jim:
 [/size]
 [/quote]
188 is correct, 024?
Mon, Mar 25, 2024 8:41 AM
Reply to Ricky:
Hi, Ricky.
"9U188024" would indicate that there were at least 188,024 of that mode buitll. IF this is correct, I suspect Cat would probably like to know what happened to the money from all the ones that they didn't know they built - - - if you get my drift.
Mon, Mar 25, 2024 10:36 AM
Reply to Ricky:
To many digits, only 5 for those old D6's. Missed that the first time. They made the first one in 1947 and the last one in 1958. With a total of right at 30,000 9u's made.
Sorry if my question bothered you, but don't want to explain it from the invention of wheel so to speak. So it helps to know where you are in the process. This is something most can do themselves if that is your way.
Mon, Mar 25, 2024 10:51 AM
Reply to Ray54:
Hi, Ricky.
I'm no 'ex-spurt' but, from what you have posted, I think you probably have about two reasons for this happening:
!. As mentioned earlier, the discs may have worn grooves in either or both the outer and/or inner splines and are hanging up on those wear marks.
2. The hydraulic booster plunger is sticking in its bore in the steering booster unit.
It'z bin a LONG time since I was inside wunna those units - about 55 years - but I think there is supposed to be a spring in there to return the booster slide to the disengaged position. If you are a financial member, there may well be a manual in the tech, library that you can access.
I think I would look at the booster first simply 'coz it is the easier area to access.
Mon, Mar 25, 2024 12:05 PM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
