Bought a d4d yesterday new member from NE Mexico
Showing 1 to 10 of 95 results
Captain Beans
Send a private message to Captain Beans
Hi,
I bought a dozer its a d4d, serial number is 78A1594, it says Group Number: 4K6037, I would like to know if I can download an operators manual from somewhere, i tried starting the dozer today it was a big failure, i had no idea which lever was the throttle, i used 2 12 volt truck batteries in series, after pulling what i believe was the throttle lever one of the batteries terminal melted because the lead wasnt tight enough i think, I stopped tinkering with the machine until I find an operators manual. Any info would be appreciated.
José
Fri, Jan 12, 2024 9:23 AM
bulletpruf
Send a private message to bulletpruf
Jose - If you pay for membership here, there are some manuals available in the library. Not sure if it would have the ones you need, however.
I recently found all the manuals I need for an old D7 on eBay. I would start off with the OMI.
That's odd that you melted a terminal, but I haven't seen that happen from something being too loose. Anyway, as you may know, you can hook two 12V batteries up as 12V or 24V; perhaps you had one of the cables on the wrong terminal?
Where are you located? Might have a member nearby who would be willing to help. Any pictures of the D4?
Scott
Fri, Jan 12, 2024 9:48 AM
Captain Beans
I am located in north east mexico close to monterrey mexico and brownsville texas, photos:
Yeah so I wanted to know if the manuals here in the library section would include the model i got or not because its not really vintage i think its from 1975, but i am not certain, i am finding out that its a 78a1 so it was made in the USA ill keep looking and also on ebay  like you mention thanks!
Fri, Jan 12, 2024 10:04 AM
bulletpruf
Reply to Captain Beans:
I'm in San Antonio; always up for an adventure, but that's about a 5 hour drive each way. A bit too far.
If you signed up for membership, you should have access to the library, but sometimes you have to send a reminder e mail.
Scott
Fri, Jan 12, 2024 10:16 AM
gauntjoh
Librarian
Reply to bulletpruf:
Scott
There is a parts book and Lubrication and Maintenance instruction book in the library.
 [attachment=74906]08EA8D4B-7698-4724-9426-938067A18A5A.png[/attachment]
You cannot download the whole document, but can read on line and screen print individual pages.
You must be a paid up member of ACMOC to access the library.
Fri, Jan 12, 2024 11:10 AM
Captain Beans
Reply to gauntjoh:
ok! i will think about getting a membership the thing is my priority is running the engine i bought it from a mechanic with a big workshop he claimed and showed to me that everything was in good condition but when i got the dozer delivered it had no battery and no operators manual of course bc its a 1976 machine. Thanks fren!
Fri, Jan 12, 2024 8:55 PM
Glum
The lever on the right side of the dash is the throttle control. [attachment=74909]Screenshot_20240112_175420_Chrome.jpg[/attachment]
Two batteries in series is correct. If the wiring is correct, turn and hold the starter switch to the left for about a minute, then to the right to crank the engine with the throttle lever wide open.
Interesting that you have a toolbar blade on a D4d series. Wish I had your disc.
Ebay seems to be the place for manuals.
Fri, Jan 12, 2024 11:06 PM
d4e
Send a private message to d4e
Reply to Glum:
I see you have a rome disc in the background . would be interested in the serial number i had 13 at one time not many of those tbh 16s around . They are the only disc that would stand. up to our work cutting fire breaks .
Sat, Jan 13, 2024 12:41 AM
Thank you received: 85
Reply to d4e:
Welcome to ACMOC
You posted several photo's, so are we to assume it ran and was unloaded on it's own power?
What changed that you can not start it?
Did the seller demonstrate the workings and offer to give you any instruction?
I hesitate to think of starting at full throttle, I never liked going from no oil pressure to full throttle.
There should be a detent on throttle that you have to pull it open to deliver fuel, Shut down is to idle then past the detent. You should be able to feel that when you move the throttle.
CTS
Sat, Jan 13, 2024 8:59 AM
Captain Beans
Reply to d4e:
The disc harrow is a 5 and 5 disk front and back the diameter of each disk blade is 26 inches, the brand is "durable" made in mexico i think it could be a rome plow clone, the brand durable has good reputation here in mexico not sure in the rest of the world, its got a serial number and a model ill take photos tomorrow!
Sat, Jan 13, 2024 9:29 AM
kittyman1
NOT a fan of full-throttle starts either ! once it starts i want to verify oil pressure first, then i'll slowly increase RPM speed...there's a lot of iron (and oil) to warm up to operating temp
Sat, Jan 13, 2024 9:40 AM
