Stuck fuel cap
11 months 1 week ago #253019 by GrantJ
Stuck fuel cap was created by GrantJ
I have a Cat 22 that probably has not run in 20 or more years. I cant  get the fuel tank open. I have tried PB Blaster and Liquid wrench with no luck. I gave up on the big pipe wrench before I ripped the spout out of the tank.  I really dont want to take a heating torch to it and maybe blow myself up. Any other ideas???       Grant.
11 months 1 week ago #253021 by neil
Replied by neil on topic Stuck fuel cap
Vibrate it off - I've had that cap stuck on my cousin's Twenty Two and applying vibrations to it 180 degrees apart did it. I think it worked because unlike a steady pull, any "grab" for want of a better term was let go by the repeated on-off pressure. Used a massager (no, not that sort : )
11 months 1 week ago #253026 by trainzkid88
Replied by trainzkid88 on topic Stuck fuel cap
you could try a needle scaler on low pressure. some times you need to do something up first to get it to undo
11 months 1 week ago #253029 by GrantJ
Replied by GrantJ on topic Stuck fuel cap
I had not thought of using the needle scaler. My go to is typically heat but a torch and a gas tank dont go well together. I will give it some "Good Vibrations" this week.
Thanks Grant.
11 months 1 week ago #253030 by Ray54
Replied by Ray54 on topic Stuck fuel cap
Any rusty parts the vibration method can work wonders. Using 2 hammers one bucking and one hitting with the other works great on pipes. Or this tank cap.
11 months 1 week ago - 11 months 1 week ago #253035 by Deas Plant.
Replied by Deas Plant. on topic Stuck fuel cap
Hi, Grantj.
Sometimes with things like fuel caps or pipe fittings, or well exposed nuts, freezing them or at least applying some form of severe cooling will help - takes time to chill the offender and then let it warm up again to ambient temp. but it tightens the outer fitting on the inner part and then lets it expand again - creates compression and then release. Dry ice works well or simply packing ice around it can do the trick.
It'z sorta the reverse of freezing a track master pin to make it go in easier.
Last edit: 11 months 1 week ago by Deas Plant.. Reason: Missta word
11 months 1 week ago #253036 by GrantJ
I will try all of the above. They make sense to me. Thanks.
11 months 1 week ago #253045 by trainzkid88
the two hammer trick is how most steering joints are done if you dont have a joint separator. the second hammer acts sort of like a mirror and gets the hit to bounce back.
11 months 1 week ago #253049 by dpendzic
Replied by dpendzic on topic Stuck fuel cap
I use a 1500 watt heat gun when i don't want an open flame
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
11 months 1 week ago #253051 by Mike Hudson
Replied by Mike Hudson on topic Stuck fuel cap
I think you could get a heater band to just about fit that. Get it cherry red for you. And I must tell all I have never used ice, but I think I like heat the better.
Time to create page: 0.202 seconds
