cat 22 mag
cat 22 mag
16 years 1 month ago #21846
by fstelma
i had the mag rebuilt by mainely magnetos about 6 months ago, ran the cat a total of maybee 3 x sat for about a month, now i cant get it to fire, could it be an impulse starter on the mag? and how to check that? any info would be great, thanks.
16 years 1 month ago #21847
by WyoCat
I would check to see if you are getting spark. The next thing to think about is this. If you shut the gas off and let it run out, it may take a while for the fuel pump to push fuel over to the carb. You can put some gas in the priming cups and see if it goes.
Chad Enyeart
16 years 1 month ago #21848
by fstelma
i have not pulled the plugs as of yet, the fuel pump is by passed and the carb is gravity fed, i filled the primer cups several times and no luck. i do have it parked on a slight hill im thinking that maybee when im filling the cups is not flowing the right way? thanks.
Thank you received: 215
16 years 1 month ago #21850
by bruce oz
hello fstelma ,if it has sat out side it may have condensation inside the mag ,check inside distributor cap and were the leads go in and inside the top lid for any moisture, you can dry it in a warm oven ,don't toast it ,lol,bruce oz
16 years 1 month ago #21851
by fstelma
bruce, thanks will do that may be the prob? its under cover but still in the humid fla air.
16 years 1 month ago #21855
by JasonPayneCrawlers
Hello Fstelma
I have a Cat 22 I took it to rough and tumble in PA this year and when I got back I left it outside till the next show in two weeks the show came and it would not start the mag was full of condensation I put a small flame to dry it up, I had to pull start to get going but after running a while it started up on it own hope this helps.
16 years 1 month ago #21858
by fstelma
Jason, thanks for the tip ill get deeper into it tommrow, trying to get it ready for the nov show here, frank
16 years 1 month ago #21887
by fstelma
shes up and running again, found some moisture in the mag, thank you guys for all your help!!
cat 22 mag
Time to create page: 0.165 seconds
