Liner Bands
1 year 3 days ago #252680 by Alexjfrench
Liner Bands was created by Alexjfrench
Does anyone have any experience installing liner bands on CTP liners?  I am installing new liners in a D47U (D315) and I cannot get the liner bands to work.  When the bands reach the bottom of the counter bore they are too thick and keep the liner from going all the way down.  There is not really a lead in on the counterbore to kind of funnel them down in there.  The original Cat liners did not have a filler band but they used a copper shim to seal them up.  The shim I used on these is stainless so Im not sure that is going to work very well for sealing these up.  Do I have to use the filler band?
1 year 3 days ago #252683 by D4Jim
Replied by D4Jim on topic Liner Bands
I have Never put a liner in a Cat but many in John Deere with an O-ring. Make certain the shoulder in the block is squeaky clean before lubing and installing the O-ring and liner. Make certain you have the correct size O-ring. For what it is worth I always used soap as the lubricant as oil often causes swelling and makes the installation difficult. Don't get hammer happy but gently use a dead hammer to gently get the seal started. Hope that helps.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
1 year 3 days ago #252688 by Rome K/G
Replied by Rome K/G on topic Liner Bands
Use the the metal shims and check liner height. Check those new liners too, know of a shop that used CTP liners on a 3408 and two of the eight were egged shaped and wouldnt fit in the block.
1 year 2 days ago #252694 by Busso20
Replied by Busso20 on topic Liner Bands
All the 3412/6 and 3516/8 engine I have built we would put the seal rings in a tin full of oil then install immediately (one at a time) as the oil will swell the rubber to help seal once installed, normally have some push back out of liner but we would hold them in with 2 bolts and washers to keep in place, I would suggest check how far from from bottom seat to make sure no issue, only rubber fighting you is normal,
I hope this helps?
1 year 2 days ago #252696 by Alexjfrench
Replied by Alexjfrench on topic Liner Bands
Does the shim under the top of the liner flange actually provide a seal or is that the job of the head gasket? I think I might be think about this wrong. Can coolant technically get past the shim and around the flange only to be stopped by the head gasket?
1 year 2 days ago #252698 by trainzkid88
Replied by trainzkid88 on topic Liner Bands
the oring is the seal. the shims sets the liner height.
1 year 2 days ago #252700 by Alexjfrench
What o-ring?  I realize the 3 o-rings at the bottom keep the coolant out of the oil but what seals the top of the liner?
1 year 2 days ago #252702 by trainzkid88
the shims set the liner protrusion so it mates properly with the head gasket and thus the head. well thats my understanding anyway
The following user(s) said Thank You: CATERPILLARHAVEN
1 year 2 days ago #252703 by rax200
Replied by rax200 on topic Liner Bands
Hi Alex,
Here is a photo of the old liner i pulled from my d315 showwing where things go.
Do not to forget to set the liner hiight this is done by placing the copper washer under liner top then place the liner in the block (no orings yet) an place a bar across the liner top and measure the clearance between the bar and block, i dont have the specs so i call on OM do you have them please and the diagram on the setup please.
Once you have them all within spec you can then install them with the orings on.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
The following user(s) said Thank You: Busso20
1 year 2 days ago #252704 by Old Magnet
Replied by Old Magnet on topic Liner Bands
This is for the 4-3/4" bore but most of the specs apply.
Time to create page: 0.195 seconds
