Choker cable size for a D2???
Showing 1 to 10 of 24 results
GrantJ
I am going to be buying a couple of chokers to tow logs with my D2. I have a 1/2 inch cable that seems to be overkill. The rigging company seems to think that 3/8 is too small. I would like opinions from people that have  done some pulling with a D2. I suspect the rigging company is used to dealing with much bigger machines.       Thanks. Grant.
Fri, Oct 20, 2023 11:15 PM
5/8" is minimum Hyster Spec required for the D2 winch, 440 feet. and 305 feet of 3/4" is also used. Line pull, bare drum is 14,000 lbs, full drum is 6,600 lbs.
Fri, Oct 20, 2023 11:37 PM
GrantJ
Wow, I was way off with my guess. I see local logger sometimes using 1/2 inch and thought that was more than I needed. I dont have a winch on my D2, so it will only be the horsepower and traction making the strain, so I may go with 1/2 inch. I dont recall what drawbar pull is supposed to be on a D2 5U but shock load can add to the actual working load. I am learning. Thanks, Grant.
Fri, Oct 20, 2023 11:49 PM
Thank you received: 15
Reply to GrantJ:
I wonder if the Hyster spec is adaptable to the current range of ropes available. Presumably Hyster came up with that spec based on the bare drum line pull combined with some pre-determined shock loading (typical over-spec multipliers I've seen in various industries range from 1.5 through 3).
Sat, Oct 21, 2023 12:14 AM
side-seat
Thank you received: 5
Sat, Oct 21, 2023 12:30 AM
GrantJ
I cant find the drawbar pull in the new operators manual I just bought for the 5u. I am heading for the ranch and have several J model D2 manuals to look thru. If anyone has the drawbar pull, I would appreciate seeing it.
I think that I will get on the Bailys email list. Looks like lots of good information. Grant.
Sat, Oct 21, 2023 1:30 AM
Thank you received: 21
Reply to GrantJ:
Overkill?
Do not sacrifice your safety and safey of others.
Straight pulls without any kiinks or bends are different than what you may experience pulling logs.
Nothing cuts through everthing in the path like a cable under tension when it fails!
Many stories of high-line logging, cat logging where cables have caught or broken, results are not pretty.
Just my humble opinion.
cts
Sat, Oct 21, 2023 1:51 AM
Reply to ctsnowfighter:
Overkill?
cts
Early D2's had 5690 lbs. drawbar pull and later D2's had 7250 lbs. drawbar pull.
Sat, Oct 21, 2023 2:05 AM
GrantJ
ROME, thank you. That is much higher than I expected. I will be going to the larger size. Probably 5/8. I will call my logger friend tomorrow and see what he uses behind his D4.
Thanks to all. Grant.
Sat, Oct 21, 2023 8:45 AM
Thank you received: 29
Reply to GrantJ:
i use a chain. you can easily buy rated drag chain from most auto stores look in the off road accessories. and it usually comes in a nice carry bag and has a proper hercalloy loop to attach it to your draw bar.
just remember the load MUST always go into the back of the hook as this is where its strong and made to take load.
if you double the chain back on itself it will grab tight and not let go ive had upto 3 logs under tow with the same choker loop
chains tend to fall dead unlike rope or cables.
Sat, Oct 21, 2023 4:29 PM
Reply to trainzkid88:
Hi, trainzkid88.
Yep, chains do tend more toward falling to the ground BUTTTTTTT - - - if itza link that breaks, where is that link likely to end up???????????????????
Once saw a 7,000# rated lifting chain break 'coz the bloke in the towed truck selected 'backwards' when he shoulda had oughta selected 'forward'. Yes, the chain was not very 'aerodynamic' - - - - - - but they could not find the link that broke. And there were a good few people watching too.
Sat, Oct 21, 2023 4:40 PM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
