I'll measure them and see if I need new ones. The service manual shows the pinion removed and disassembled to replace the bearings and seal, but I think the seal looks easy enough to replace with it in the machine.
48A1697
I don't think there is anything wrong with the gears, just leaking from the bevel gear case into the drive on one side. The brakes are OK but near the end of their adjustment.
I was in a hurry and typed gears, the part that is no longer available is the 5M5037 inner hub on 160 hp. tractors. This is the part which is usually worn and causes the finals to leak if tightening the sprocket adjustment doesn't eliminate the leak.
48A1697
I don't see anything in the service manual about tightening the sprocket adjustment, is it as simple as tighten it if its loose?
