Model 12 8T Motor Grader Fan Belt Replacement
Showing 1 to 10 of 10 results
PaulBmf
Send a private message to PaulBmf
I am working on my Model 12 Motor Grader serial number 8T17669.   I need to replace the worn out fan belt with a new Cat belt 7B-2774  .  I was able to remove the old belt from the pulleys and remove it by sliding past the fan blades.  I can get the new belt over the fan blades and onto the top or bottom pulley, but not both pulleys at the same time (too tight).  Pictures of the old and new belt and a picture with the belt removed are attached.
Is it possible to install the new fan belt without removing the radiator and fan/pump?
When I have more time I am also planning to remove the radiator and pump to research the cause of the belt damage.  I suspect a damaged adjuster (picture attached) and/or play in the pump bearings is causing the problem.  The pump was rebuilt and new belt installed 6 years ago.
Thank you.
Wed, Sep 27, 2023 3:03 AM
NEVER beat on that adjusting ring where the lock bolt goes through, now you bent it in and screwed up the threads!
Wed, Sep 27, 2023 4:09 AM
PaulBmf
Thank you. That makes sense now that I cleaned out the slot behind the where the lock nut goes through. It looked solid when it was full of dirt and grease. I saw a prior post about using a spanner to help break it loose and save the threads. Of course, that was after this one was already damaged.
Do you think the threads and adjusting ring are something that could be repaired?
Still curious if its possible to install a new belt without removing the radiator and fan/pump.
Wed, Sep 27, 2023 4:51 AM
Reply to PaulBmf:
You might be able to take a chisel and open that back up, but may still damage the threads. Yes just get the belt around the fan then install it on the pulleys. Make sure you have the right belt for that serial number, some fan pulleys were different diameter and used a different belt.
Wed, Sep 27, 2023 6:12 AM
Thank you received: 7
The fan pulley groove sides are worn as well which will hasten belt wear. If you're going to pull the pulley off, you could send it to a shop and get him to reface the faces back to the correct consistent angle. Ideally you'd want to do it to both the fan and crank pulleys. While you have the fan pulley off, use a thread file to clean up the adjusting threads - you should be able to spin the adjuster half by hand. To loosen or tighten, jam a rod (wrench, whatever you have that will fit) from the adjuster webs to a suitable place and then turn the fan blades. That way you're not pounding on the adjuster
Wed, Sep 27, 2023 9:27 PM
d2gary
Some antiseize on the threads will make it a lot easier the next time you have to adjust the belt
Thu, Sep 28, 2023 2:06 AM
Reply to d2gary:
The proper tool for adjustment is an adjustable spanner wrench with the right size pins.
Once the lock screws are removed the holes a counter bored to accept the pins (before there buggered up).
D4's use 1/4" pins, D6 uses 5/16"
 [attachment=73853]AMF Face Pin Spanner #1.JPG[/attachment]
 [attachment=73855]AMF Face Pin Spanner #2.JPG[/attachment]
 [attachment=73854]AMF Face Pin Spanner #3.JPG[/attachment]
Thu, Sep 28, 2023 3:38 AM
caterpillar13
use a hacksaw blade to clean some of the damage up, then tap a small screwdriver in the slot and adjust it, dont worry about the sides of the pully you are probably not going to run it enough to hurt the belt
Thu, Sep 28, 2023 6:28 PM
Thank you received: 11
Reply to caterpillar13:
Hi, PaulBmf.
The new belt should go on without removing anything - assuming that you have the right belt. Bear in mind that old belt would also have been somewhat stretched and so you may need to back the adjustment off a bit more on the top pulley. I would be starting by adjusting the top back some more and then putting the belt over the top pulley first.
If it is missing out by a LOTTTT, it may be that you have the wrong belt for your machine.
Going by the look of that fan pulley, the wear showing there would cause belt damage, A photo - or two - of the old belt may also give a clue. You could run a new belt on that pulley but it would likely quickly wear to a similar shape.
Try wiggling the fan to see if there is any movement in the fan bearings. Funny thing about fan bearings on these machines - if the bearings are worn, it is likely that the seals will be leaking.
DON'T take too much notice of this post 'coz I'm 'justa pore, dumm bulldozer op'rator' so what would I know about graders?
Fri, Sep 29, 2023 5:56 AM
Thank you received: 28
Hi, PaulBmf.
i wondered how they where adjusted. i knew you turned the nut to close up the sheave and thus adjust the belt. but how it was supposed to be turned was a mystry. thanks OM. the other name for them is gland nut spanners many hydraulic rams have pin type gland nuts.
Fri, Sep 29, 2023 4:19 PM
Reply to trainzkid88:
Hi, Folks.
You can 'ackshully' make your own wrench for adjusting these fan pulleys. It requires two arms set apart by slightly more than the diameter of the center threaded section of adjustable side of the pulley and attached to one handle.
Each arm needs to have either a pin embedded into the end of it or the end of the arms turned downward at right angles to the handle so that they can engage the ribs radiating out from the center to the outer edge of the pulley. Place one side behind one rib and the other side ahead of the opposite rib depending on whether you need to loosen or tighten the belt.
This eliminates the need to start beating on things that were never made to be beaten on.
BUTTTTT, what would I know??? I'm 'justa pore, dumm bulldozer op'rator', not wunna them smart 'wrenchbender' types who get to 'revive' what us op'rators kill.
Fri, Sep 29, 2023 5:07 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
