Flywheel ring gear
Flywheel ring gear
1 year 2 months ago #251288
by mc
Folks, I am new here and like the site. I have had yellow fever most all my adult life. just sold a D5H XL and for some reason I needed a replacement with something as old as I am to fill the hole it left, so I picked up a 1954 D2 , 5U 14511.
not working! Issue is it was jammed up and would not turn over. finnally freed it up and turning the engine over by hand there is a clunk at the same spot in a complete revolution each time. I have narrowed it down to 3 missing teeth on the flywheel ring gear. Hoping that is all the damage there is. Going to attempt to remove it through the access cover.
question: Where can I get a replacement gear?
can you buy any gaskets for these D2's, or do you need to make yourself.
Also, are there any old yellow fellows near me, (Pembroke, NH, USA) with one of these.
thanks
marc
You do not have permissions to access this page.
Thank you received: 788
1 year 2 months ago #251290
cat does have gaskets for these old girls. if you have a parts book you can check
www.parts.cat.com for availability. if you register you can even order via your local dealer. ive had success even with a phone call to the dealer parts desk.
1 year 2 months ago #251316
by mc
Thanks, will try them. still will be looking for that flywheel ring gear 7B 6248 if anyone knows where I could source one.
thanks again.
marc
Thank you received: 26
Thank you received: 36
1 year 2 months ago #251320
by sheddcanyon
I was able to source an aftermarket ring gear for a 1942 4R D6 a few years ago through Florin Tractor, which is now closed. So I think they're out there. Might take some sleuthing.
Thank you received: 818
1 year 2 months ago #251328
by mc
I did look at the parts book and see it is a 7B6248 that it needs.
Not sure how much difference between that one and the one on machinery trader which is as you mentioned a 7B 6249.
thank you for your effort
marc
Thank you received: 660
1 year 2 months ago #251367
I guess you know more than the parts book but mine shows two different assembly numbers for the flywheel and different part numbers for the ring gear. Are you sure your dealing with the right s/n?
Flywheel ring gear
Time to create page: 0.197 seconds
