318 thermostat retaining rings
HUDCO
Send a private message to HUDCO
what is the best way to remove the thermostat retaining rings without 3b7184 , tool thermosats are not bad , but i have to weld a long crack in the housing
Thu, Sep 14, 2023 5:06 AM
bcwayne
I have been successful in removing them by grinding the head of a bolt to fit the slot in the retaining ring, and fit the bolt to a slide hammer... work it out one side at a time.
Thu, Sep 14, 2023 10:38 AM
HUDCO
Reply to bcwayne:
good idea i did not think about a slide hammer i will do that in the morning be fore we open the shop thanks
Thu, Sep 14, 2023 10:41 AM
Thank you received: 30
Reply to HUDCO:
try a blind hole bearing puller most of the come with a slide hammer in the kit or can be mounted to one. and it would pull evenly. if you can get one big enough is another question.
Thu, Sep 14, 2023 11:25 AM
Newby Hall Tractor Fest
