Caterpillar 60 vacuum tank
Showing 1 to 7 of 7 results
ChrisRoyd2
Send a private message to ChrisRoyd2
Does anybody have a picture of what should be on top of the vacuum tank. I belive I am missing something, but unsure by looking at the manual.
Mon, Sep 4, 2023 11:23 AM
Vacuum Tank
Mon, Sep 4, 2023 8:22 PM
ChrisRoyd2
Is the blue circle just a plug that you can remove to add fuel? And is the red circle a vent or is it a check valve of some sort. The manual is not very clear. Thanks
Mon, Sep 4, 2023 8:45 PM
willwingo
Attached are the instruction sheets for the SW vacuum system:
[attachment=73587]sw vacuum tank 1.jpg[/attachment]
[attachment=73588]sw vacuum tank 2.jpg[/attachment]
[attachment=73589]sw vacuum tank 3.jpg[/attachment]
Source: ACMOC Newsletter, April, 1996
Mon, Sep 4, 2023 9:59 PM
ChrisRoyd2
Reply to willwingo:
Thank you that helps me understand how this works. With any luck it will be running by the end of the day.
Mon, Sep 4, 2023 10:32 PM
ChrisRoyd2
Reply to ChrisRoyd2:
The good news is, I got it to draw fuel, but now it still don't run right. It seem like the carburetor adjustments don't do anything. According to the book the idle should start at 1/2 turn out and high speed at 1-1/8 and adjust from there. It almost seems to be flooding. Have double checked float level and seems good. Any ideas. Thanks
Fri, Sep 8, 2023 10:47 AM
ChrisRoyd2
[attachment=73634]20230812_125452.jpg[/attachment][attachment=73635]20230812_125436.jpg[/attachment][attachment=73636]20230812_125442.jpg[/attachment]
Fri, Sep 8, 2023 10:56 AM
ChrisRoyd2
Serial number PA9389
Fri, Sep 8, 2023 10:58 AM
Chapter 2 The Link Club's AGM
