Cat HT4 Questions
Cat HT4 Questions
Thank you received: 8
1 year 1 month ago #250666
by Cat955Hdvr
Gentleman,
I am going to look at a Cat HT4 for sale in near me in Ohio, I have a couple questions about the tractor before I go. I've attached a picture of the tractor as well as a few others I found online with similar equipment.
My first question is it looks like the HT4 has dozer mount points on the track frame? Is this common or did someone possibly mount D4 7U frames at some point? I attached some photos of an HT-4 with a blade mounted which was attached to the loader arms. I don't think the owner has the loader frame, with the previously mentioned mounting points...could I mount a blade if I wanted to?
It also looks like it has the wrong pads on the machine, dozer pads vs loader pads.
does anyone more knowledgeable notice anything? I only have the Trackson Serial, no D4 serial number. Also, trying to find out if this unit is locked up or just doesn't run...so more to come on that.
thanks for any help,
Nick
Thank you received: 642
1 year 1 month ago - 1 year 1 month ago #250670
My HT4 parts catalog show a bulldozer blade that attached to the loader arms, but it also shows an angledozer attachment that attached at the points you show in your photo, and was raised lowered by linkage to the loader, if I'm interpreting the parts diagram correctly. That could explain the mount in your photo. My buddy has an HT4 and the track frames are bare on the outside so it could very well have supported a Cat 4A/S mounting arrangement too, possibly a tool bar arrangement as well.
Last edit: 1 year 1 month ago by
neil.
Thank you received: 999
Thank you received: 267
1 year 1 month ago #250683
by rax200
It has in seat starting and an oil clutch and I would also say 5 roller track frames
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 1 month ago #250686
It would have a rigid frame though, not very good for a dozer setup.
Agreed, I doubt Trackson sold many of them, just not the right tool for the job compared with a purpose-built bulldozer
Thank you received: 317
1 year 1 month ago #250696
by Ray54
I picture 3 you can see a clevis welded on the under side of the loader arm as well as bars on the U frame . I am guessing the bars are pined to the arms to lift the dozer blade.
Not that familiar with the 7u and the HT4. Guessing since the same base unit the track frames could be traded back and forth . Probably even the track frames for the heavier undercarriage would bolt on. If they did that in the same time period as the 7u.
1 year 1 month ago #250697
by Cat955Hdvr
@Rome K/G - Ya, i'm watching a few including the one you sent me...I wasn't sure if for scap value this one was worth saving for some of the options mentioned (dual circuit hydraulics, 5 roller track frames and a decent looking undercarriage).
@neil - As always, you are a wealth of information. I agree, it's probably was not the best tool for job...just wondering for the money if it's worth saving for any purpose other than parts. I hate seeing old yellow iron go to the torch.
Thanks to everyone else for the feedback
I'll put out an update once I go see it.
Nick
1 year 1 month ago #250778
by CATERPILLARHAVEN
Hi all I have a picture of the blade which Trackson call it AGH4 ANGLEGRADER
I do have the mounting fittings on my ht4 but the blade etc where long gone when I bought the ht4.
Cheers Wayne.
Cat HT4 Questions
