D7-17a starter conversion
Thank you received: 815
Thank you received: 772
1 year 3 months ago #250651
by juiceman
Canevari Bros. located in Woodland, CA has a repair center, part of their parts store. The fellow that does alternator/starter repairs etc. has helped many in the past with electric start conversions. Many of the local farmers use them for the starters; American International Manufacturing? used to sell the adapters for the alternators (Woodland, CA)
Mike B. here on the BB might remember who the names are. I'm getting old and suffer from CRS. JM
1 year 3 months ago - 1 year 3 months ago #250652
Yes, we conclude that at one time these came out of Woodland but I don't think there has been any conclusion on who is currently the manufacturer and is supplying Auto-Lec.
Thank you received: 786
1 year 3 months ago #250654
what im doing for a alternator conversion is using the factory bosch housing and gear with a new and longer shaft with a locking collar to keep it in the right spot and a vee pully on the end past the rear bearing with a bracket for a one wire alternator. the advantage of this is I can get the alternator to the "right" driven speed and have it charge correctly even from idle I simply change the driving pulley to get the right ratio. it also allows easy changing if the alternator dies and that model is no longer available etc.
6 months 5 days ago - 6 months 5 days ago #256849
by PPardue
Adwest, did you get this solved? If so, can you share how? I'm facing the same issue right now with my 17A. Talking to Auto-lec, the 371-12144 housing is no longer available. I see the MT50s listed on ebay advertised as fitting but with the incorrect helix. If those units do, indeed, mount up then the issue of machining the correct bendix is less of an issue.
Last edit: 6 months 5 days ago by
PPardue.
6 months 4 days ago #256881
by PPardue
If so, great. I guess I was more concerned about if the nose was actually the correct one for a 17a.
I reached out to a couple of the sellers on ebay for clarification but it's clear they are not versed in the various flavors of D7 and if this one was correct for a 17a.
5 months 3 weeks ago #257173
by PPardue
OM, you say there's no shortage of the RH drives. I might be looking in the wrong places but can't find any in stock under the 12197 part number. I was able to source the correct starter nose but, as with adwest, it has a LH.
