Cat d4-7U pulls corn chopper
1 year 3 months ago #250224
by FarmerD5
I would like to hear your input about cat d4-7U with 2 speed pto pulls corn chopper or silage. Have anybody done it and wonder if it works good.
farmerD5
Thank you received: 660
1 year 3 months ago #250234
I'm definitely interested in the video when it comes out. I can't get enough of PTO and pulley-powered operations with crawlers : )
I've seen a guy baling with one, and another pulling a brush hog but no choppers
Thank you received: 999
1 year 3 months ago #250235
by Rome K/G
Yes, many farmers did years back when fields were too wet for wheel tractors, it has been done.
Thank you received: 405
1 year 3 months ago - 1 year 3 months ago #250250
by D4Jim
Back in the 60's our neighbor used a 6U to pull a 2 row chopper. He used a 4 row mounted planter at that time. Don't remember the brand of the chopper.
That being said the planted corn populations around here were probably less than half what is planted now. Truck followed the chopper so no wagon pulled by the Cat.
Don't remember it being much different cutting rate than the similar chopper we used on a Super WD-9. Chopped corn was placed in a trench silo.
I believe the 6U was about 1954 or 55.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 1 year 3 months ago by
D4Jim.
Thank you received: 788
1 year 3 months ago #250252
it would certainly drive the implement just fine standard pto speed is 540rpm.
the ground speed might be the issue.
plenty of farms in aus use tracked tractors in cotton and grain crops.
Thank you received: 71
1 year 3 months ago #250253
by Dandy Dave
I can remember my Dad using an International T6 crawler on the farm in the 1960's to pull our John Deere 2 row corn chopper around the field as it was too wet for a wheel tractor to go it alone.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
Thank you received: 16
1 year 3 months ago #250257
by CRS93082
We have run combines and other pto implements on D2s and D4s. No issues other that the pto is not a live shaft so when you disengage the main clutch the pto stops. Not a huge deal but it would be nice to be able to stop the tractor and let the machine catch up when you start to plug up.
Thank you received: 47
Thank you received: 502
1 year 3 months ago #250274
by ctsnowfighter
8C361 - good point
Many do not realize those clutches can be used to stop all forward movement and allow one to take machine out of gear in emergency situations.
I had a pin come out of the master clutch linkage inside the housing, at the time I was discing prunes and a limb caught the radiator cap, tail seat 7UD4
No place to hide! Certainly not the time to discover a pin had fallen out!
CTS
Thank you received: 774
1 year 3 months ago #250278
by juiceman
A large farmer here had some orchard D4's with PTO's. Can you imagine having that pto shaft under your behind and so close to your ankles? They actually had operators pull brush choppers with it. I would be scared to death! I tend to think those particular versions were more suited for turning a stationary irrigation pump, not a death trap on tracks. JM
