D 6 9U track chain question
Showing 1 to 6 of 6 results
d4angelo
Our museum in Vista California has a D6 9 U with a broken track chain. We only put about 20 hours year on the machine annually. Question#1: Do we need to disassemble all of the links from the master pin down to the broken link to make the repair or can we just replace the broken link? Question #2: Do we need a track press to do the work or can we just drive the pins out with a big sledge hammer? If anybody in the Southern California area has part #5B2293 or 5B2294 please let me know. Any help is appreciated.
Sat, Jul 29, 2023 10:56 AM
PhilC
The broken track link will need to have the bush cut in half to get it out of its mating chain link. When reassembling with a new bush you need to use a master link bush or cut the bush down to allow it to fit between the chain links. Doing it this way you basically end up with two master links in the chain which is not an issue.
We used to use a big sledge hammer with a good dolly as close to the pin as possible. Given you are removing standard pins you may need some heat as well to get them moving.
Other members have welded links with good success so that may be an option as well.
Sat, Jul 29, 2023 2:35 PM
kittyman1
Reply to PhilC:
i don't understand, see the problem first hand...but i can assure you any half ass welder can weld cut links...and no issues..
-i believe you always want to break the track at a master link whenever possible, always the easiest way to connect (reconnect)
Sun, Jul 30, 2023 3:59 PM
Thank you received: 11
Reply to kittyman1:
50 years since I was a track press operator turning pins and bushings.
Memory serves correctly - all links except the master link are press fit, bushings to inside of the rail segments and pins to the outside portions, thus creating a chain.
Bushings on the master link hold the alignment of the narrow end of the rails, PRESS FIT! The pin on the other end of the "chain" holds the alignment of that segment of rail. Then the master pin is driven through the outer rail segments, a tight fit but not of the tonnage required for the rest of the chain pins and bushing.
This said - you can cut the pin/bushing with torch, cutoff wheel, etc but how are you going to remove the portion of the bushing in the rail segments?
Same goes for the pins. Those are tight fitting and require high tonnage to push out!
A broken link required total disassembly of the entire chain, just as turning pins and bushings. Not something that can be done with a sledge hammer and pin punch!
Sometimes one would install a second master link but that was not a common practice. Again - required total disassembly of the entire chain on a track press.
Typically, turning pins and bushings tightened the chains, but did nothing to the rail wear. It was a less expensive fix than new chains
CTS
Sun, Jul 30, 2023 7:30 PM
PhilC
Reply to ctsnowfighter:
CTS
[quote="ctsnowfighter post=250170 userid=9709"]50 years since I was a track press operator turning pins and bushings.
 [/quote]
You are mostly correct except you can install a second master link without dismantling the entire chain. Seen ti done many times and have done it myself. As you know the only difference between a normal link and a master link other than the press fit is the length of the bush. The master link bush does not protrude past the edge of the chain and that is what you have to duplicate either with a new master link bush or by cutting the protruding bush flush with the link side. Heating the link half to get it back onto the bosh helps but you can also create another master link setup with it as well. Seen it done and lasted until the chain was retired many many hours later. If you have the adjustment then  you can leave a link out and shorten the chain.
You are also incorrect about being able to remove non master links with a hammer and punch. I have also seen that done many times and as mentioned stubborn pins will require the link to be heated. Haven't seen it done on anything bigger than D8 chain though.
I don't understand why you would install a second master link unless you are joining two lengths of chain together WITHOUT dissembling the entire chain.
Mon, Jul 31, 2023 3:21 AM
Reply to PhilC:
 [/quote]
Link repair......
 [attachment=73124]Link-Repair.jpg[/attachment]
Mon, Jul 31, 2023 3:37 AM
Link repair......
Thanks Old Magnet
As always, you are a source of vast knowledge.
As I said - 50 years ago, a lot of water has gone under that bridge. I do not recall ever putting a second master in, always brought to shop and broke the chain down on track press.
CTS
Mon, Jul 31, 2023 10:25 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
