Hi, Pioneernorth.
Looks good to me - - - although I am looking at it from DowNunda.
MY D8 14A has a final drive leak on outer side of sprocket. I understand these old machines have felt seals that probably won't seal if the sprocket nut is tightened up. It is a good running machine with new crankshaft & bearings. Will SAE 250 gear lube in the final drive give this machine extended life.
