Recent 20 rescue
Recent 20 rescue
16 years 1 month ago #21720
by equipdriver
So the next problem is the Carb. I opened it up and found a piece cracked. The float does move and seams to be of decent shape. Any ideas on if I need to replace the part or is there some bandaid to put on it to help me get the tractor running?
I have yet to try to pull start it due to the carb but will give it a try once the carb is on line.
Thanks,
Karl
16 years 1 month ago #21732
by bgates
My Twenty hadn't been run in about 18 years. It had no compression in three cylinders and little in the fourth. I put Marvel Mystery Oil in the cylinders, changed the oil and put in fresh gas, retorqued the head, cleaned and gapped the points and replaced the plugs. I about wore my arm out cranking it, but it finally started. It spit, puked and blew oil everywhere until I covered the radiator to get the heat up. Then the rings finally seated and it runs great.
I should have pull started it like these guys are saying. It would have saved a lot of time.
16 years 1 month ago #21744
by carlsharp
Hey Driver- that crack sure looks brazable, at least I would try, unless there is something I can't see...
CS
16 years 1 month ago #21755
by equipdriver
If I were to braze the crack would that stop the fuel from coming out the botom strainer? The float feels like it works but I think the fuel is going through the crack. Would JB weld work since I dont know how to braze?
thanks
Karl
Thank you received: 64
16 years 1 month ago #21767
by 3J1Bill
I think I saw the part you need at Woodland. Bill Cambell (705)488-2802 had new cast out of brass parts on his table. Bill
16 years 1 month ago #21812
by equipdriver
Bill, eventually I will be sending the carb up to Mr Cambell. For now I will just be trying to get the unit started. JB weld seams like my best option.
thanks,
Karl
16 years 1 month ago #21880
by Jon
The main body of the carburetor is brass. there are four screws holding the split part to the main body. I have had several of these carburetors apart, that piece was not brass. I am assuming that this one is not either.
Recent 20 rescue
Time to create page: 0.165 seconds
