caterpillar D2 stuck steering wheel
Showing 1 to 10 of 14 results
OSO
Send a private message to OSO
I watched the video to repair a stuck steering wheel; however, I'm not able to drag the machine around as suggested in the video. Does anyone have any other suggestions?
Wed, Jun 7, 2023 6:22 AM
https://youtu.be/PZeDFwTcnCc
Wed, Jun 7, 2023 7:05 AM
Kurt Bangert
You may have us scratching our heads on the steering wheel portion of your question, do you mean a steering clutch? Or one of the tracks not releasing? Does the D2 run?
Wed, Jun 7, 2023 7:10 AM
Thank you received: 12
Reply to Kurt Bangert:
Couple of options;
- tighten up the adjustment and then pull the lever to see if that will release the clutch
- disassemble the steering clutch and separate the disks manually
Wed, Jun 7, 2023 10:40 AM
Couple of options;
I have a brand new set of steering clutches for ya out of a Cletrac that will bolt right up!
Wed, Jun 7, 2023 9:45 PM
Thank you received: 16
Hi, ROME K/G.
That'z NOT nice, teasing like that. LOL.
Thu, Jun 8, 2023 2:57 AM
Hi, ROME K/G.
Was this not a question from a new member seeking advice? (Did I miss something and read this wrong?)
Where would you go with a Caterpillar question?
The club has been through some very tumultuous times, struggling to retain members and gain new ones.
The very existance hinges upon the mutual interest in the machines and sharing knowledge and practices with others.
Let us not lose sight of that common thread and goal, helping one another pursue our addiction/affliction to the Caterpillar Tractor and equipment.
Now on the lighter side (in good humor)
Rome K/G, would you please video your methods and procedures of installing those Cletrac Steering Clutches in the functional drive train of a Caterpillar D2.
I am relatively certain it would be most informative and at minimum entertaining.
Stay Safe Everyone!
"keep 'em crawlin'"
CTS
Thu, Jun 8, 2023 5:16 AM
Hi, ROME K/G.
https://youtu.be/hw3CE04LGiA
Thu, Jun 8, 2023 5:17 AM
OSO
Sorry guys...I typed the wrong word I meant clutch...
Thu, Jun 8, 2023 5:42 AM
Reply to OSO:
https://youtu.be/-04cD3xKO_Y
Thu, Jun 8, 2023 6:16 AM
Reading between the lines I think most had it figured that you were dealing with a steering clutch issue.
I have seen them so rusted that the only thing to do was throw the whole assembly in the proverbial scrap pile.
D2's seem to have an issue with moisture and steering clutch probems and they are worn the drum and the clutch plates are often beyond salvage.
Lots of good information on this website, do your research.
Good Luck!
"keep 'em crawlin'"
CTS
Thu, Jun 8, 2023 7:12 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
