Nalcool prevention for calavation
novavalleycat
Send a private message to novavalleycat
Back in the 80's or 90's at caterpillar I could by a product called Nalcool they tell me it is not available,does anyone know of a replacement for this product used to prevent calvation of the piston liners
Thu, Jun 1, 2023 10:06 PM
kracked1
Go to your local NAPA. They handle a very comparable product.
Thu, Jun 1, 2023 10:42 PM
Thank you received: 85
Reply to kracked1:
Nalcool and Nalprep! I haven't heard those names since the 90's. Great stuff. Had some engines torn down and the mechanics said my liners were perfect. The stuff must have really worked. I don't remember WHY we had them taken apart though. LOL. I do not understand why they do not offer coolant treatment/filters for current engines, or am I mistaken. JM
Thu, Jun 1, 2023 11:35 PM
Cat SCA [beet juice] part # 3P2044 1 quart bottle $9.13 from Cat
I add a quart every 250 hrs at oil change.
Fri, Jun 2, 2023 1:36 AM
steeltracs
Thank you received: 5
Some of the antifreezes have SCA mixed in it. Wix calls their treatment Wix-Cool. John Deere has a coolant treatment also.
Fri, Jun 2, 2023 4:32 AM
Reply to steeltracs:
Yes, I use the standard pink Cat coolant also.
Fri, Jun 2, 2023 4:49 AM
Thank you received: 33
i use a product called eco cool aoc1000 by australian organic coolants it has a life of upto 6years/12000hrs and is suitable for all vehicles that dont need freeze protection at a mix rate of 7.5 percent with demineralised or distilled water. it has anti corrosion anti cavitation properties.
they also have a specific diesel coolant aoc 2000which is anti cavitation anti scale anti corrosion anti electrolysis film forming protection for engines with cast iron blocks and cooling systems
Fri, Jun 2, 2023 7:46 AM
rhartwick
Send a private message to rhartwick
Reply to trainzkid88:
Do older engines, like in our older D2's, etc. need any of these modern antifreezes or additives? I use regular green Prestone @ 50:50. It seems like the cooling systems on these machines were originally designed to run on anything from pond water to alcohol. Growing up in the 60's, I never heard of anyone using diesel specific antifreezes. If they are better or prevent a problem, I'll use them but I always assumed they were only for the more modern diesels.
Fri, Jun 2, 2023 6:27 PM
Reply to rhartwick:
Always good to use a rust preventive.
Fri, Jun 2, 2023 9:19 PM
Price Tractor Pull
Price Tractor Pull
