Magneto ground wire D47U
Tuna
Send a private message to Tuna
Putting a starter motor on the pony motor, I need a longer mag ground wire.  It has a 7mm spark plug wire currently for the ground wire. Can a use a 12 ga wire for the grounding wire?  I know to run it out of gas on the pony and not use the kill switch, but want it working just in case.
Wed, May 17, 2023 10:47 PM
Thank you received: 100
Yes, 12-14 gauge wire will be okay. Add some wire loom to protect it from chaffing or heat.
Please share some photos of your project please. We like pictures. JM
Wed, May 17, 2023 11:40 PM
Tuna
I have to relocate the starter solenoid as I won’t clear the hood. The money and effort was worth it as the pony motor starts so easy now.
Fri, May 19, 2023 5:16 AM
Reply to Tuna:
Yessiree,, that has had to be done here a time or two. Electric pony start is the way to go if one doesn't go DE.
Did you already have the electric for the pony or did you purchase? I had a D2 that needed to be converted and it seems to have taken me major effort to find all the bits and pieces. I want to say it was an isolated incident. Thanks for the picture. JM
Fri, May 19, 2023 5:29 AM
Thank you received: 34
just give the bonnet the gurney bubble treatment or cut a hole so it clears it. kidding just mount it elsewhere. a electric start pony is the best of both worlds for these old girls.
Fri, May 19, 2023 10:08 AM
