D6 9u get going without elctric start or pony
16 years 1 month ago #21411
by wabster
Is it possible to pull the d6 with a large articulated trucck... volvo A30 and then start the d6 by engaging the transmission like pust starting a standard transmission auto ???? could you tell me if it is possible to do a rolling start on a 9u 1957 d6 by pulling it with a large articulated dump turck volvo A30.. since I dont know if the diesel is intact I would pre fer to see if I can make it start prior to either rebuilding the pony or doing an electric start... your thoughts and advice on this and if yes the best way to proceed after the blade is placed in an up position.. thanks wabster
Thank you received: 80
16 years 1 month ago #21415
by gemdozer
Yes you can pull the d6 and you have to angaged the master cluch and the transmission on high speed with compression and trottle on and he should start quick.
Thank you received: 820
16 years 1 month ago #21416
Not a good idea to attempt pull start unless you know for sure the engine is free, otherwise you may cause damage in the process.
16 years 1 month ago #21623
by d7doug
I have 2 of them 9u's and pull start both of them or run them down a hill, go easy on the clutch and heavy on the either make sure the foward reverse lever is pulled back toward the seat for the forward position.
Time to create page: 0.131 seconds
