#44 Hydraulic seals gaskets.
Showing 1 to 10 of 12 results
Ross1956
Send a private message to Ross1956
Hello guys, I have been looking online for a while and can't find anything on the parts I need. I am going to attach some photos if the site will let me. if anyone knows the correct replacment filters and seals I would be greatful even a direction to look, our local cat dealer is more then a pain to deal with. I am looking for the replacement filter for the unit, Cat number on the one I have is 7f7238 and the drive seal 1j-8162
  [attachment=72071]image_67184641.JPG[/attachment][attachment=72072]image_67208193.JPG[/attachment][attachment=72073]image_50447361.JPG[/attachment]
Tue, May 2, 2023 12:36 PM
josh
If your cat dealer is not doing the job, try another, I would give Peterson Tractor in San Leandro Ca a call.
The filter is probably going to be Cat only, They do have it, and it has been expensive for a long time.
https://parts.cat.com/en/petersontractor/7F-7238
The seal is common, Cat and other sources will have it, crosses to 5F4721.
https://aftermarket.express/caterpillar/1j8162
Tue, May 2, 2023 1:31 PM
Ross1956
Reply to josh:
thanks a ton man, I will give Peterson a call, again thanks.
Tue, May 2, 2023 1:46 PM
Thank you received: 28
Reply to Ross1956:
yes they do have the filters not cheap. the seal you could get generic from any bearing joint if i understand the markings that was a chicago rawhide seal anyway.
Tue, May 2, 2023 2:52 PM
rax200
Hi All,
The seal updates to 3H1397 and the filter is only a bypass filter and they are no longer available, so if yours is not to bad just was it out and put it back in.
Regards
Tue, May 2, 2023 2:57 PM
PNW.Hillbilly
Send a private message to PNW.Hillbilly
Reply to rax200:
Hi All,
Regards
Filter is ONLY available from Cat. I've been through a ton of interchange manuals and there is nothing close in dimensions. It's like $65 now.
Seal is easily available on ebay, just search for 1J8162 or 3H1397
Tue, May 2, 2023 11:37 PM
Thank you received: 30
Reply to PNW.Hillbilly:
Thanks Matt. Great to know here, as I plan on servicing several 44's myself included. Glad you did the hard part for some of us already!
Oh yes, any new projects on the way? I haven't been following YT lately; didn't know what mischief you may be up to. Enjoy all of your videos! JM
Tue, May 2, 2023 11:47 PM
side-seat
Thank you received: 5
PNW Hillbilly, That filter from the dealer, Is it a metal one, or paper type like the oil filters?
Last time I bought one (Metal) of those about 25yrs ago they were like $42 ea so I bought two.
Wed, May 3, 2023 1:19 AM
josh
Reply to side-seat:
The #44 units use two different filters, depending on the serial number of the unit, one is the 7F7238 metal wrapped paper filter, the other is the sock or wound filter like the fuel filter, I think it's the same # as the fuel filter, 2A5886. Both filters provide the same function, only difference is a few parts that hold the filter in place.
Wed, May 3, 2023 1:51 AM
PNW.Hillbilly
Reply to josh:
[quote]side-seat post=247860 userid=956
Last time I bought one (Metal) of those about 25yrs ago they were like $42 ea so I bought two.[/quote]
It's for the metal one, $68 when I ordered it last November
[quote]josh post=247861 userid=654
The #44 units use two different filters, depending on the serial number of the unit, one is the 7F7238 metal wrapped paper filter, the other is the sock or wound filter like the fuel filter, I think it's the same # as the fuel filter, 2A5886. Both filters provide the same function, only difference is a few parts that hold the filter in place.[/quote]
The old sock one is the same part number as the fuel filter...which you can get for around $10.  This actually brings up a reasonable question though...why not convert the pump back to using a sock instead of the $70 metal filter?  What other components would you need?  Here are the components that are different between the two setups circled:
 [attachment=72087]pump.png[/attachment]
Looks like you need the retaining rod assembly 5B9966, a random plate 5F3381, and a different bottom cover 5F3432.  The seal 4F7390 is a generic o-ring, so ignore that.
Here is what is in a fuel filter housing:
 [attachment=72086]fuel.png[/attachment]
So you basically have everything you need from one of those fuel element assemblies except for the 5F3381 plate (probably just use a washer for that?), and the bottom cover.  Maybe you could modify the bottom cover off the later setup to fit it?  I don't know, just an idea to save yourself a few bucks if someone wants to try it.
Wed, May 3, 2023 2:34 AM
josh
I always thought the change over would be a reasonable way to go, the 7F7483 coverplate used on some of the #44 units with the 7F7238 metal filters, interchanges with the 5F3432 coverplate used on the 2A5886 filter.
The filter system on those #44 units don't do much, really best to take the front cover off and clean it out properly if your going to change the filter or service it.
Wed, May 3, 2023 9:45 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
