Parts Catalog for Early D4 (7U931)
Thank you received: 8
1 year 7 months ago #247650
by Dirtbiker1824
Hello,
I scrubbed the tech library for a parts catalog for my D4 dozer with serial number 7U931, but the best I found covers 27570-44307. Anyone know where I could find this info? While I have many projects on-going with this dozer, the one I'm currently tackling is the starting engine. The block assembly is the "Devil Block" - big thanks to @squatch253 for documenting so much work on YT, and I'm worried the seals and gaskets that I need to order will be different between that block and what's listed in this parts catalog. I do know this starting engine is used on some D2's so I searched through those parts catalog and couldn't find any that called out the 4B666 block.
Thanks!
Thank you received: 999
Thank you received: 60
Thank you received: 80
Thank you received: 276
1 year 7 months ago #247659
by rax200
Hi All,
I just scanned a better copy of the 7u1-up parts book last week and Deebo up loaded it in just search for 10506 that is the form number.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 6 months ago #247775
by Dirtbiker1824
Thank you all for posting these! Not sure why I missed these in my initial search....
Unfortunately none of these manuals list the block as 4B666 which is what's on my D4 - I suppose it was swapped out at some point. Does anyone know which parts manual would cover the 4B666 block assembly?
Thank you received: 418
1 year 6 months ago #247776
by Deebo
I’ve had a brief look through the D4/D2 parts catalogs and can’t see the “so called Devil block” listed as 4B666, nearest I see is 4B671. I’m never sure if the numbers on the actual castings correspond to the part numbers or are just casting numbers. Might be worth PMing Sasquatch as he’s done extensive YouTube (Squatch253 on YT) starting engine stuff. This link will get you started;
The good thing is a lot of parts for all these pony motors are totally interchangeable and you may find even if you find a parts catalog for that block someone may have changed the top cover or other things at some point.
Thank you received: 663
1 year 6 months ago #247777
Dirtbiker, the casting number is not (necessarily) the part number. Your block has the tractor serial # on it so use the catalog posted above to find parts for your block. You don't have to overthink it : )
Deebo
Thank you received: 186
1 year 6 months ago #247778
by josh
4B666 is the casting number, the block assembly is 4B671.
Deebo
Thank you received: 788
1 year 6 months ago #247783
according my 6u parts book its the top cover and exhaust manifold thats different and thus a different gaskets for those parts. but the block itself is the same and it was only for the first 700 machines.
but that doesnt mean anything as the early machines could have been "upgraded" to the later setup. as it all just bolts on.
Deebo
Time to create page: 0.199 seconds
