CAT 22 spark plug cover
16 years 1 month ago #21348 by biggastractor
I am finally getting around to putting my spark plug cover on my 22 and I lost the studs that go into the block. My memory says they are fine thread on one end and coarse on the other. Can anyone give me the correct dimensions or have a spare set they would sell. The tractor is about 50 miles from home and I don't there very often in the fall.
Biggastractor
16 years 1 month ago #21357 by WyoCat
Replied by WyoCat on topic CAT 22 spark plug cover
Yes they are course on one end and fine on the other. I will get you part numbers here later today. Cat still has them.
Chad Enyeart
16 years 1 month ago #21358 by SJ
Replied by SJ on topic Studs
The R2 shows just 3/8"D. X 3/4"long bolts for the plug wire tube clips.I,d think you could use bolts too and if there is spacers between the clamp and block you,d need bolts a little longer. I don,t have a 22 book so can,t check just what setup they have for sure.
16 years 1 month ago #21359 by WyoCat
There are 3 different lengths. The middle two are the same. The front one is rather short. And the rear one is a middle length. But I believe SJ is right, they are all 3/8" fasteners.
Chad Enyeart
16 years 1 month ago #21360 by SJ
Replied by SJ on topic Bolts
Wyo, I should have said they are standard 16 threads on the 3/8" bolts.
16 years 1 month ago #21361 by catalac
Replied by catalac on topic Reply to biggastractor
Hi biggastractor,
Serial number 2F1087 and later and all 1J serial numbers use part number L-2332 at the rear of the head, part number B107 in the center two positions, and T101 at the front of the head. The early 2F series used L-468 at the rear of the head with the other three parts being the same as the later tractors. Four 1B4203 nuts are required.
I am going to need a set of them too. I will try Capital Equipment here in East Peoria, but I have lots of other things to do before I need them.
Regards,
Lee
Lee Sorbel-ACMOC Past President
16 years 1 month ago #21378 by biggastractor
Thanks for all your help, guys. I appreciate it.
Off to play with steam engines, threshing machines and sawmills today.
Biggastractor
Time to create page: 0.158 seconds
