D8L SA for Neil
D8L SA for Neil
Thank you received: 774
1 year 7 months ago #247539
by juiceman
Neil: I didn’t want to highjack the D4E thread; I did reach out to the ex Mrs. Finch, and she does remember them having an 8L!!! Go figure! Scary part is she remembered too well, as it’s nickname was “the boat anchor”.
Apparently a lot of transmission issues she said.
She will see if any photos are available if it for your lurking pleasure. JM
Thank you received: 663
1 year 7 months ago #247543
You're a champion JM! Thank you! I would be very interested in what she observed about the transmission, and I'm guessing it was the two-speed hydraulic clutch. The rest of the transmission is no different to a powershift model so standard reliablity.
Have they scrapped it?
Thank you received: 321
1 year 7 months ago - 1 year 7 months ago #247544
by Ray54
Part of the SA was that it was not a power shift. Cat engineers under built dozers as compared to ag work. In that in dozing they figured half the time backing up to get another load of dirt to push. In a ag work more or less a constant high degree of load. One of the weaker points of D8 Hand K was in vineyard ripping they ran hot all the time. What convinced one operation here to run 3 or 4 Fiat Allis FD 30's for ripping. I was surprised to see one still out and ripping last fall.
The only first hand information on a D8 L SA I have is a cousin drove one with a YIELDER no till grain drill. The drill was such that it held 20 ton of seed and fertilizer giving a lot of weight on the tongue. They had a lot of track roller and rear bogey issues.
After reading the other thread no need to look for this D8 L SA it was a rental from Quinn Cat over 25 years ago.
Last edit: 1 year 7 months ago by
Ray54.
1 year 7 months ago #247548
by juiceman
Turns out it belonged to the Kaiser Ranch, not Finch, but apparently everyone knew of its "issues". It may possibly be there still; she will talk to her ex hubba bubba some more.
She says that I OWE her now. Someone please explain what that might entail? The things I do for you guys! JM
1 year 7 months ago #247549
I'm sure she would swoon over your grilling skills JM so that might put you way over on the positive side of the ledger. Ray, on the D8L SA, almost the only difference between that model and the regular non-SA is that it had a two speed hydraulic clutch instead of a torque convertor - everything else was the same in the driveline, including the 3-speed F-R powershift transmission. So I'd be interested to hear which part of it was giving trouble on Kaiser's machine. The guy that I followed up with on the Ag Trader machine reckoned his was in good shape and in regular use, and he sold it to a buddy that had lusted after it for years. I'll bet most of them were sold in CA and the Northwest so the dealers round that way might know how often they came in for repairs. Still, it wouldn't matter to me if it was unreliable; I'd have one for the cool factor! : )
Thank you received: 215
1 year 7 months ago #247556
by bruce oz
12 ? or so came to Queensland Australia , all came up fpr Aution on the same day ,i think they where used on cotton farms ?
1 year 7 months ago #247559
by juiceman
Interesting where some might have ended up. The initial spotting, I said that HAS to be the oddest looking tractor (being a hightrack) pulling a drag disk of things. It is supposed to reside along with other crawlers this guy owns, and nothing for sale sadly. Nothing. They hold tight to their stuff. JM
1 year 7 months ago #247561
by Ray54
Are you sure Neil, what Bruce has posted agrees with what I was thinking. But my information is just memories of the sales brochures, so I sure could be wrong. As I understand the reason for the SA tractors was to build direct drive tractors and to make provision for weight on the front, since the base machine was designed to balance with a blade on the front.
I have direct experience discing a orchard, the same mountain with different old 9u D6's. My first had a hydraulic hardnose and 20 inch track shoes walked right up. A number of years latter I asked to disc again. Different 9u no hardnose, but 24 inch shoes and it was a fight to climb that hill every pass. And plain dug a hole and was never going to make it up in that row. It was the same size disc as many tight places limited how wide could be used. So balance is important on how much traction is available even with tracks. But I don't think they would had a separate designation to just denote a tractor without a blade.
1 year 7 months ago #247578
Yes, just the two-speed clutch in the diagram that Bruce posted, in the driveline. It did have other different parts not in the driveline, such as the counterweight that he posted that sits under the radiator, four hydraulic outlets on the rear with the four levers in the cab on the operator's right hand side, the clutch control also on the right which was a u-shape similar to the main transmission control, where left-to-right changed the speed from direct to under, and then backwards feathered the clutch into engagement. It also had a tachometer mounted above the dash, and a set of headlights up front in addition to the usual set of field lights.
bruce oz
D8L SA for Neil
Time to create page: 0.473 seconds
