Figured out this old wrench
Showing 1 to 7 of 7 results
Steve1ac
Send a private message to Steve1ac
After doing many hours of research on this form and deciding to make up my own plug removal tool and researching old cat wrenches I remember seeing this in the old man’s toolbox and wow it fits thanks to all.
 [attachment=71889]image.jpg[/attachment] [attachment=71889]image.jpg[/attachment]
Sun, Apr 16, 2023 9:20 PM
seiscat
Hello Steve, A newer and better drain plug wrench is available from Caterpillar.
Craig
 [attachment=71890]DP 3.jpg[/attachment]
 [attachment=71891]DP 2.jpg[/attachment]
Sun, Apr 16, 2023 10:17 PM
Steve1ac
Reply to seiscat:
Craig
Wow I like it since that’s coming from caterpillar that’s probably $50-$75. If it’s like any of the other machinery that’s green or red. What I don’t understand is with the belly pan or the skid plate whatever you wanna call it ,with them plugs up in there 4 to 6 inches how was the mechanic to get that wrench up there through that little hole and unscrew the drain plugs looks good on paper.
Mon, Apr 17, 2023 1:10 AM
seiscat
Reply to Steve1ac:
Current price for 212 8146 is $48.49 USD.
Craig
Mon, Apr 17, 2023 9:06 PM
willwingo
Reply to seiscat:
Craig
If you are planning to use that finger pinching, knuckle buster - a simple fix:
Saw the handle off and use a socket on the opposite side to remove/ replace the plugs.
If for some reason you don't want to cut this piece of shit off - this is one alternate: 1 1/8" hex head bolt cut off and crudely welded.
 [attachment=71897]plug socket.JPG[/attachment]
Tue, Apr 18, 2023 1:45 AM
Reply to willwingo:
Or just put the wrench up through the pan then put a socket on it.
Tue, Apr 18, 2023 3:16 AM
seiscat
Reply to willwingo:
The "inverted hex" of the drainplugs are tapered, so to get a full contact non-marring tool get a Caterpillar tool. Yes, the "welded nut" tools will work. They just don't have the look and the cool factor.
Craig
Tue, Apr 18, 2023 4:20 AM
D4Jim
Thank you received: 10
Reply to seiscat:
Craig
An 18" cheater pipe makes the on and off easier with the Cat tool. Mash the end of the tube or pipe on the handle to control the orientation of the spud with the pipe.
Cats Forever
Tue, Apr 18, 2023 5:29 AM
Newby Hall Tractor Fest
