D2 Cluch or tranie
D2 Cluch or tranie
16 years 1 month ago #21326
by 2bluejon
I just bought a new D2 and after i got it started i tried to move it and it had a knocking sound in the tranie. When you pull in the cluch it was knocking. well we started to load the cat on trailer i got it up about on and it sounded like it was not in gear it would just grind so i backed it off and got a little better run and got it on and then it felt like some gears were messed up what do i do and where do i start i am perty new at this thanks
Thank you received: 10
16 years 1 month ago #21333
by ccjersey
Well, the first thing is to quit driving it (as much as possible)!
What is the serial number? Probably doesn't make much difference with the transmission like it would with the clutch. Any difference in which gears seem to be affected?
You will have to take off the seat and top covers to see what is going on in there. To remove anything, you have to pull the shafts from the back end, so any pto or winch back there will have to come off.
From further study, it seems the clutch shaft has to come out the front to remove the gear cluster and bevel gear shaft (top shaft in transmission), so if you have a later style clutch which is removable w/o pulling the engine, you would be well ahead. The lower transmission shaft is the one that has to come out the back if you happened to need to get into it that deep.
There's a lot of stuff right there on top like shifters and clutch interlock mechanism that could be the problem that would only require removing the seat and top covers to get to it.
16 years 1 month ago #21346
by compressor
2bluejon,
First thing I would do would be to remove the transmission tower.Really kind of self explanitory.make sure you put the transmission in neutral,this makes it alot easier to reassemble.Look and see if everything is still glued together,if it is my bet would be the lower set of gears have come unglued.the problem is there are 2 small screws in the front of the transmission that acts as a retainer on that shaft.This makes it a huge pain to repair if you have the older style D2.You will have to remove the engine to repair. If it is a newer one 13237 and up you might be able to repair without removing the motor.Even if you do have the newer style,be ready to stand on your head ,because to do this job right, it will be a real challenge. Been there,there done . GOOD LUCK COMPRESSOR
16 years 1 month ago #21353
by 2bluejon
thanks for the help wher i get closer i will keep you posted that makes me feel beter about the job thanks
Thank you received: 47
16 years 1 month ago #21354
by 8C 361
Are you sure it is not just the clutch slipping? There are parts that can come loose and bang around in there.
16 years 1 month ago #21355
by timbo1946
What about the external teeth on the main clutch disk comming apart? From initial discription it sounds like the tractor stopped moving when loading.
Tim
Thank you received: 32
D2 Cluch or tranie
Time to create page: 0.168 seconds
