D8800 power unit
1 year 7 months ago #247085 by Joshua
D8800 power unit was created by Joshua
I’m new to the group and have a D8800 power unit on my sawmill. I think it’s a 1948 the serial number is 6S7218. The other day i had one of the rubber clutch links brake and it broke the pinion shaft off the pony motor. My local cat dealer says the shaft is obsolete but I found a new old stock on line. My question is do you guys think I should fix the pony motor or convert to electric start?  Both routes look expensive but pony motors seem to start better. The main engine runs very good and will start good in the cold. I just worry about needing starting fluid all the time with electric start.
1 year 7 months ago #247086 by neil
Replied by neil on topic D8800 power unit
Do you have electric power at the location? If so, you could rig up a block heater, which can help with starting, or install a flame-start on it, if you want to go electric start.
1 year 7 months ago #247088 by Wombat
Replied by Wombat on topic D8800 power unit
Replacing the pinion shaft would be relatively inexpensive and a simple fix compared to converting to direct electric start and the associated problems with heating the main engine for stating. Why would you not just replace the broken shaft???
Wombat
1 year 7 months ago #247089 by d2gary
Replied by d2gary on topic D8800 power unit
I would repair the pony motor, those Cat engineers were pretty smart. I would imagine with an engine that size it probably saws all the time when it's running , with a couple of guys feeding it. I'm assuming it's a production mill, anyway if you are only starting it a couple of times a day and its warm the pony will start it easy. If you are starting and stopping a lot maybe an electric starter would be the way to go. Not familiar with your engine but maybe pony start and electric.
I've had a sawmill in one form or another for 20 or so years, I'd love to see pictures of your set up. Video of it sawing?
1 year 7 months ago #247091 by Joshua
Replied by Joshua on topic D8800 power unit
I’m totally leaning toward fixing the shaft. It’s just the shaft alone is about 500 bucks and I would hate to get into it and spend a lot of money and need that one part I can’t find. I definitely like to keep old equipment original. The mill is a Lane no1. When everything goes right I can saw 3500 to 4000 board feet per day but I’m still working the bugs out of it.
1 year 7 months ago #247095 by trainzkid88
Replied by trainzkid88 on topic D8800 power unit
photos please pictures say a thousand words. if i understand you properly you were starting it when the failure happened.
1 year 7 months ago #247099 by Joshua
It was running. I was sawing and one of the rubber clutch links on the main clutch broke and snap the pinion shaft off the pony motor.
1 year 7 months ago #247102 by Rome K/G
Replied by Rome K/G on topic D8800 power unit
I do have the shaft, sent you an email/message.
1 year 7 months ago #247104 by Kurt Bangert
Replied by Kurt Bangert on topic D8800 power unit
Welcome to the Club! Good luck on the repair, sounds like you're getting good advice here.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
1 year 7 months ago #247110 by Joshua
Here is a video of last fall
Time to create page: 0.188 seconds
