Login | Register
Zenith Carburetor
Zenith Carburetor
willwingo
This is described as #  20, JET - Idle on the Zenith Carburetor Restograph sheet.
How should the distal end be finished? Does is close against a seat?
It appears to be beaten up but would still pass fluid.
[attachment=71535]028.JPG[/attachment]
[attachment=71536]zenith carburetor restograph.jpg[/attachment]
Mon, Mar 20, 2023 5:40 AM
I believe its open on the end.
Mon, Mar 20, 2023 6:24 AM
side-seat
 [attachment=71544]2092492a46682dca6816b2fd2f0d5e19[/attachment] [attachment=71543]image.jpg[/attachment] [attachment=71542]image.jpg[/attachment]Just so happens there’s one sitting on the bench
Mon, Mar 20, 2023 7:37 AM
Reply to side-seat:
https://youtu.be/2TnkJ8_BmSI
Mon, Mar 20, 2023 9:01 AM
Shaban1983
Send a private message to Shaban1983
Zenith P/N: C51-2-10
Macdonald Carb: $16.40 https://www.mcdonaldcarb.com/product_p/c51-2-.htm
It can also be sourced from Cat dealers for about $50, p/n 5F-7640
Also same one used on John Deere tractors, p/n AR13009
You may also need to replace the fibre washer it seats against:
Zenith P/N: T56-48
Cat P/N: 9B-4446
Tue, Mar 21, 2023 3:03 PM
willwingo
Reply to Shaban1983:
Zenith P/N: T56-48
Cat P/N: 9B-4446
Steve and Shaban - thanks for the help.
Will
Tue, Mar 21, 2023 6:54 PM
Booleroo 2025
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
