D2 And D4 engine Interchangeble Parts
Showing 1 to 10 of 15 results
Mitch Mc
Send a private message to Mitch Mc
Hi Everyone,
Im from Australia and i have a D4 5J with a cracked head and therefore has rendered it useless, is there any parts that interchange between a D2 and a D4 engine as i have a oppourtunity to buy a complete D2 diesel and pony motor as a unit fan to flywheel.
Thanks for your help.
Sat, Feb 25, 2023 8:41 PM
The cylinder head doesn't unfortunately and that sounds like the part you most need. The pony motor does, and there may be parts like the generator, thermostat, etc. that might interchange.
Sat, Feb 25, 2023 9:05 PM
rax200
Hi Mitch Mc.
Nuts and bolts interchange as do the pilot motor, starting clutch but unfortunately nothing else.
What part of the country are you in?
Send me a PM with your number
Regards
Sun, Feb 26, 2023 3:17 AM
Thank you received: 30
Reply to rax200:
Hi Mitch Mc.
Regards
place a wanted ad on this forum maybe someone can help you.
have you tried tillys they might have one. also try pual moore both are at toowoomba
depends how bad and where its cracked they can be repaired by a method called locknstitch. they can also be welded or brazed as these are cast iron and steel any good engine reco shop should be able to do it for you. make some phone calls. remember your not going and earning money with it, its a restoration.
just becuase it is cracked doesnt mean its unusable. cast iron and steel isnt like aluminium.
do you have photos of the head where its damaged.
Sun, Feb 26, 2023 8:45 AM
Busso20
Reply to trainzkid88:
MitchMC, there was a complete one advertised on FB in Geraldton complete I think with pony
Tue, Feb 28, 2023 7:25 AM
CATERPILLARHAVEN
Send a private message to CATERPILLARHAVEN
Hi Busso20 that Caterpillar motor is sold because I went up and bought it today but it's not a D4 D4400 it's a D2 3j D3400 no tag block date 1946.
I am thinking about selling my spare 4g rd4 head but I've got too check the condition of the rest of the motor out first whether I keep it for going motor or a part motor.
Cheers Wayne 👍
Tue, Feb 28, 2023 7:19 PM
Busso20
Reply to CATERPILLARHAVEN:
Cheers Wayne 👍
Hi Wayne, well at least the motor went to a good home, My D2 is a 3J 1920 1938 model, I do have a D4 6U if you're in the market? I will ask a fella I know if he has any leads on the head for you in the south west.
Tue, Feb 28, 2023 7:27 PM
CATERPILLARHAVEN
Cheers Wayne 👍
Hi Busso20 thanks for the offer for the D4 6U I'm still thinking about it as I have a few more project Cats on offer at the moment as you know you get one then it's two and it's Cat fever👍but what is the condition of your D4 6U ?
Cheers Wayne
Wed, Mar 1, 2023 5:11 PM
Busso20
 [attachment=71274]IMG_4867.jpeg[/attachment] [attachment=71276]IMG_4530.jpeg[/attachment] [attachment=71275]IMG_4531.jpeg[/attachment] Hi Wayne, ex works dept number 128, original working condition, new main clutch, adjusted brakes and steering, gauges, runs good, pony good and have spare pony for parts complete, all manuals from works dept, grousers low, chains pretty worn, been shed kept for about 30years that I can track.
Thu, Mar 2, 2023 4:26 AM
CATERPILLARHAVEN
Cheers Wayne 👍
Hi Busso20 I've sent you a email
Cheers Wayne 👍
Thu, Mar 2, 2023 7:17 AM
Rock
Send a private message to Rock
Reply to rax200:
Hi Mitch Mc.
Regards
Im new I have a 30s Cat RD4 4G4500 I need A Shot of the Head bolt pattern and torque specs, engine was rebuilt was advised after running for a few hour's to do the last torque process . heres a few pics . I dont have any books yet . hope you enjoy the pics.
Fri, Jun 23, 2023 12:56 AM
| Hartley - South Australia
