This should help.
these pictures are from the PT10 book and the PV15 book.![]()
Thank for the reply. I have a reprint book and I timed like the book says. But I'm more or less asking, after setting the timing by the book, then using a timing light, can a guy get the timing more accurate than just trying to see when the points "just start to open". Or is the method in the book close enough, and I shouldn't fiddle with it as it will not help how it runs?
